It is currently Sun May 12, 2024 8:09 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: FL350 frame help
PostPosted: Sun Jun 08, 2014 2:47 pm
It accelerates faster than it can decelerate. During the first test run it was an awesome feeling when it lifted the front tires right off the ground, not so much when i went to stop! I got new pads and its better now, I also put trx250r spindles, hubs, rotors and calipers on the front which helped out also. The 108c was removed from a 1990 pantera 440 and was set up for that sled. I am not sure how it is set up, I wanted to see how it worked first, because everything looked fairly new on the inside. I can look to see what is has in it if you want to know. I also ordered some rebuildable fox shocks for the suspension.
Registered users: Bing [Bot], Google [Bot], Lanix, Q, wyeeoddy
