ChrisV's fl670 build http://pilotodyssey.com/PO/viewtopic.php?f=5&t=13964 |
Page 2 of 4 |
Author: | ChrisV [ Fri Apr 11, 2014 4:35 pm ] | ||||
Post subject: | Re: ChrisV's fl670 build | ||||
i started fabbing my tank up. it should hold a little over 5 gallons. there will be a 8x3 sump on the right side for the pick up.
Author: | stix [ Fri Apr 11, 2014 6:01 pm ] |
Looks good, do you think you need baffles to keep from sloshing around? |
Author: | ChrisV [ Fri Apr 11, 2014 10:23 pm ] |
stix wrote: Looks good, do you think you need baffles to keep from sloshing around? not really. the spun tanks don't have them, the stock tanks done have them, and its only 5 gallons. the sump will have a couple 1" holes draining into it, so they will act like a baffle to keep fuel in the sump when the fuel is low. now would one hurt anything? No, and I may make one to go in it. |
Author: | nitrosport_5 [ Fri Apr 11, 2014 10:28 pm ] |
Looks good chris. May have to follow you and build myself a tank. Would be nice to have over 4 gal. Hell I'd really like 6 looks like there is room for a bit more if you made it straddle that bar. Although lots more work. |
Author: | ChrisV [ Fri Apr 11, 2014 10:33 pm ] |
nitrosport_5 wrote: Looks good chris. May have to follow you and build myself a tank. Would be nice to have over 4 gal. Hell I'd really like 6 looks like there is room for a bit more if you made it straddle that bar. Although lots more work. yea, and the way the pipe runs takes some room. I need to calculate the volume. the 1st tank I mocked up held 6.5 gallons. this one is 1" shorter. I may actually fab up another after the may ride. I have an idea that I want to try, but that will be revealed later. |
Author: | nitrosport_5 [ Fri Apr 11, 2014 10:45 pm ] |
Doh forgot about the pipe and muffler. |
Author: | B S [ Sat Apr 12, 2014 1:21 am ] |
nitrosport_5 wrote: Doh forgot about the pipe and muffler. lol haha |
Author: | stix [ Sat Apr 12, 2014 1:23 pm ] |
ChrisV wrote: stix wrote: Looks good, do you think you need baffles to keep from sloshing around? the sump will have a couple 1" holes draining into it, so they will act like a baffle to keep fuel in the sump when the fuel is low I didnt mean to insisuate you don't know what you are doing , just making a suggestion, and yes I would think 1 " holes would keep the gas from sloshing away from the pick up. Good idea! |
Author: | ChrisV [ Sat Apr 12, 2014 1:43 pm ] |
stix wrote: ChrisV wrote: stix wrote: Looks good, do you think you need baffles to keep from sloshing around? the sump will have a couple 1" holes draining into it, so they will act like a baffle to keep fuel in the sump when the fuel is low I didnt mean to insisuate you don't know what you are doing , just making a suggestion, and yes I would think 1 " holes would keep the gas from sloshing away from the pick up. Good idea! I didn't take it that way at all. Sorry if my reply was a little short |
Author: | stix [ Sat Apr 12, 2014 2:24 pm ] |
ChrisV wrote: stix wrote: ChrisV wrote: stix wrote: Looks good, do you think you need baffles to keep from sloshing around? the sump will have a couple 1" holes draining into it, so they will act like a baffle to keep fuel in the sump when the fuel is low I didnt mean to insisuate you don't know what you are doing , just making a suggestion, and yes I would think 1 " holes would keep the gas from sloshing away from the pick up. Good idea! I didn't take it that way at all. Sorry if my reply was a little short The LS trip is sneaking up on us, do you think you will have ole girl ready by then? |
Author: | ChrisV [ Sat Apr 12, 2014 3:01 pm ] |
I'm doing my best. I'll order cables Monday and that should be all the parts. |
Author: | stix [ Sat Apr 12, 2014 3:28 pm ] |
ChrisV wrote: I'm doing my best. I'll order cables Monday and that should be all the parts. Looks like you have your work cut out, we have another ride scheduled for a few weeks after this one so if not, maybe next trip |
Author: | ChrisV [ Sat Apr 12, 2014 8:01 pm ] | |||||||
Post subject: | Re: ChrisV's fl670 build | |||||||
the fuel tank is fabbed minus mounts and the taps. I made the sump larger then I had originally planned. why not go for the extra quart of fuel.
Author: | bugeye59 [ Mon Apr 14, 2014 10:16 pm ] |
Great job Chris,now go one further for safety sake. Never liked the posi of fuel tank over exhaust,motor (( Internal Combustion Engine ? )) etc,incase of leak. I would be installing a drip tray under the tank,with drain away tubes that exit to the ground. You never know when you spring a leak,all it's all behind you,and you'll only find out when it's too late mate! |
Author: | stix [ Mon Apr 14, 2014 10:21 pm ] |
bugeye59 wrote: Great job Chris,now go one further for safety sake. Never liked the posi of fuel tank over exhaust,motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) etc,incase of leak. I would be installing a drip tray under the tank,with drain away tubes that exit to the ground. You never know when you spring a leak,all it's all behind you,and you'll only find out when it's too late mate! Its the dirver mate, not everyone drives like a bat outta hell bugs, heh heh! |
Author: | ChrisV [ Sat Apr 19, 2014 5:21 pm ] | |||
I've been playing around with intake ideas but can't really find one that I like.
Author: | ChrisV [ Sat Apr 19, 2014 5:25 pm ] | ||
And one playing around with my spool mate gun. Not to bad for the 1st try
Author: | bugeye59 [ Sat Apr 19, 2014 9:55 pm ] |
Not bad at all! Pics of your spool gun? |
Author: | ChrisV [ Sat Apr 19, 2014 10:08 pm ] | |||||
Spoolmate 185 on a millermatic 185.
Author: | dbloudharleys [ Sat Apr 19, 2014 11:45 pm ] |
Looks real nice crisv , it looks like it is starting to shape up well , hope to see ya at the dunes. |
Author: | ChrisV [ Sun Apr 20, 2014 10:04 am ] |
dbloudharleys wrote: Looks real nice crisv , it looks like it is starting to shape up well , hope to see ya at the dunes. I am trying to make this trip. it will be close for sure. I still have to: 1. fab hoses 2. wire fan 3. mount CDI (Capacitor Discharge Ignition) 4. mount coil 5. wire it up 6. heat shield for seat and I have about 4 days left in my schedule to work on it. |
Author: | ChrisV [ Mon Apr 21, 2014 5:13 pm ] | ||
finished the filter housing. the K&N needs to be cleaned and oiled.
Author: | B S [ Mon Apr 21, 2014 5:23 pm ] |
ChrisV wrote: finished the filter housing. the K&N needs to be cleaned and oiled. IS IT JUST A K&N OR DO YOU HAVE THE OTHER FILTER IN THERE? IF YOU HAVE THE OTHER FILTER IN THERE I WOULD RUN THE K&N DRY WITH A PRECHARGER BAG OR PANTIE HOES OVER IT |
Author: | ChrisV [ Mon Apr 21, 2014 5:28 pm ] |
Both filters are on it |
Author: | DMoneyAllstar [ Tue Apr 22, 2014 11:50 am ] |
ChrisV wrote: Both filters are on it Awesome! Jealous...I can't weld aluminum (yet). |
Page 2 of 4 | All times are UTC - 5 hours [ DST ] |
