PilotOdyssey.com
http://pilotodyssey.com/PO/
lt rotax fl350 project
http://pilotodyssey.com/PO/viewtopic.php?f=5&t=14515
Page 1 of 3
Author:  emmanuel farrugia [ Sun Jul 20, 2014 9:16 am ]
Post subject:  lt rotax fl350 project
Ive had this frame for a few years now collecting dust so I figured its time to do something with it, so far ive stretched the frame 6 inches and had the final output shaft of the fl 350 trans machined to accept polaris rzr cv shafts. This is my second lt setup the first one had some issues and wasent going to be very easy to duplicate. I am also making a rear drive unit that will use the sled driven clutch and bolt in where the trans is
Author:  emmanuel farrugia [ Sun Jul 20, 2014 9:31 am ]
Post subject:  Re: lt rotax fl350 project
The rxr 900xp front axles are a little too long, im hoping the rzr 800 front axles are a little shorter and have the same spline as the 900 axle. Does anybody have a rzr 800 that they could measure the front axle on
Author:  Fawcett999 [ Sun Jul 20, 2014 4:24 pm ]
What front end are you planning to use? There's a front assembly for an 04-05 TRX450r on Ebay for $200 bucks. Is that something that would work well for a Fl350 upgrade. I'm considerig it but not sure what parts to use.
Author:  Kangaru [ Sun Jul 20, 2014 5:15 pm ]
Yay finally I hope this will be available as a kit?
Thanks.
Author:  DMoneyAllstar [ Mon Jul 21, 2014 9:03 am ]
Good to see this resurrected! Anxious to see the rear-drive setup. Hoping its simple with mostly off-the-shelf gears & shaft.
Were you thinking of doing a jack-shaft setup? Or an actual gear train?
Author:  B S [ Wed Sep 03, 2014 12:41 pm ]
UPDATE?
Author:  DMoneyAllstar [ Mon Sep 08, 2014 9:31 am ]
<crickets audio>
<enter tumbleweed stage left>
Author:  dbloudharleys [ Mon Sep 08, 2014 4:21 pm ]
sure is spooky in here kinda cold and dark and still quiet , mmmmmmmmmmmmmm come on scooby lets go get a snack.
Author:  bugeye59 [ Tue Sep 09, 2014 9:09 am ]
Shoosh!......I hear something?.....
F'K! :shock:
Author:  dbloudharleys [ Thu Sep 18, 2014 1:06 am ]
:-) :shock: :shock:
Author:  emmanuel farrugia [ Sat Jan 24, 2015 8:59 pm ]
The rear end is on hold until I make enough money to tool up to be able to machine internal splines myself, the center shaft cost me 800 and I still have to do the wheel hubs so there is another 800. I am doing this to eventually sell a kit but with those kinda prices well I wont sell any. Unless there is somebody on the board who is setup and works a little cheaper I would be glad to work with them. I have been working on a few projects though, here are some pics
File comment: fl 350 bolt on front end with disc brakes uses Honda 450 shocks
File comment: polaris rzr 900xp with rotax 800 2 stroke
Author:  hoser [ Sat Jan 24, 2015 9:30 pm ]
Now that should become a really fun ride any more details on this build?
It should make all them 4 stroke queers cry when you blow by them after they spent 5k on some turbo setup that never works right with your stock 2 stroke :-) then they will 'get it' (the two stroke advantage).
Author:  jknarfal [ Sun Jan 25, 2015 6:30 am ]
In the picture of the modified output shaft it appears that the splines and threads for the disc brake hub have also been removed. By doing that it offsets the axles and you loose your brake hub. Was there any reason for this other than it just becomes paper thin with those splines cut into it? I've been looking into this and what ill probably end up doing is having a new shaft made with a larger diameter splined section for the brake hub. This should cure the paper thin issue on the left hand side. This would also mean I would need a different hub for the brake disc. Wich would also be good to adapt a more common brake disc that's actually available.
Author:  emmanuel farrugia [ Sun Jan 25, 2015 8:16 am ]
I am only two days into the rzr 800 build, Ive got the Engine mount done and im sending the drawings to the laser cutter on Monday, then it will be the exhaust, wiring, guards, airbox, oil injection reservoir.
I am going with outboard disc brakes on my lt 350 setup so that's why I cut all that stuff off, I am going to make my own rear hubs and carriers, the simplest thing would be to use rzr 900 parts but then your stuck running 12 inch wheels
Author:  DMoneyAllstar [ Sun Jan 25, 2015 8:35 am ]
#1...That 2-stroke rzr is trick! Better start another thread (I smell a hijacking! lol)
#2...If you are putting a gearbox together, hell yes the one-off parts are going to be pricey. Can't build these to order and be cost-effective. You'd have to prove it out, and then get a group-buy or just invest in a big order. If its more than $1k (USD), it better rival the RPM and Team Moto boxes. No opportunity to use existing parts off anything else?
#3...What kind of heat treating on the shafts?
Author:  emmanuel farrugia [ Sun Jan 25, 2015 8:46 am ]
I have no intention of building gearboxes for the price of an rpm box its not worth it, you cant build a good gearbox for less than 1000 anyways. I have a jackshaft setup that uses six spline farmer shafts which are off the shelf, you lose the reverse in trans but if you get a newer rotax like my 800 they have electronic reverse in the Engine
Author:  jknarfal [ Sun Jan 25, 2015 12:44 pm ]
I figured that was the case. It's not a simple modification. I plan to build my own axle carriers but hopefully use common components. What is the spline count on the outside end of the razor shafts?
Author:  Kangaru [ Mon Jan 26, 2015 11:29 pm ]
Emanuel,
Will your long travel still work with the original gearbox?
If I got a new centers shaft made, and used the outboard brakes?
Thanks.
Author:  DMoneyAllstar [ Tue Jan 27, 2015 5:46 pm ]
**My dumb comment omitted. :-) **
Author:  emmanuel farrugia [ Wed Sep 09, 2015 10:09 pm ]
few pics of my bolt on front suspension
Author:  emmanuel farrugia [ Wed Sep 23, 2015 7:31 pm ]
Im now including the fuel cell and rad brackets in the conversion kit for no extra money for both the 350 and 400 to make the conversion easier
Author:  wyeeoddy [ Thu Sep 24, 2015 3:18 am ]
I like the Fuel Cell
? will that fit in a stock frame and Stock Engine,
yeoddy
Author:  emmanuel farrugia [ Fri Sep 25, 2015 3:32 am ]
Im not sure if it will
Author:  emmanuel farrugia [ Sat Sep 26, 2015 9:33 pm ]
It fits in a stock frame im just not sure about the stock Engine
Author:  bl1tzkr13g [ Sat Sep 26, 2015 9:41 pm ]
it looks like it sets where the transmission goes
Page 1 of 3 All times are UTC - 5 hours [ DST ]
https://www.phpbb.com/
