FL350 "reloaded" http://pilotodyssey.com/PO/viewtopic.php?f=5&t=14694 |
Page 2 of 3 |
Author: | KOdy [ Mon Nov 02, 2015 11:25 am ] | |||
Post subject: | Re: FL350 "reloaded" | |||
Back to originial controls.. With new brake pumps.
Author: | wyeeoddy [ Mon Nov 02, 2015 7:57 pm ] |
Looks good I like your gearbox mod Just a thought. I know Its a little late now. If you set the the Left Brake lever on the steering wheel as your clutch and the Right as brakes and set up a adjustable front and rear brake bias setup. you would not need the foot pedals. Looking forward to it running. yeoddy |
Author: | duwem [ Fri Nov 06, 2015 12:10 pm ] |
How far does the steering wheel turn lock to lock? |
Author: | KOdy [ Sun Nov 15, 2015 7:54 pm ] |
1 complete turn.. y am just using 90 degrees to de left 90 to the right.. Seems.to turn just a bit less than original.. will test soon. |
Author: | KOdy [ Sun Nov 15, 2015 8:53 pm ] |
Author: | KOdy [ Sun Nov 15, 2015 8:58 pm ] |
Attachment: 20151115_173928.jpg [ 48.57 KiB | Viewed 3092 times ] Begining to look like a finished project.. And when ready I must disassemble it to paint it. |
Author: | canadian oddy [ Sun Nov 15, 2015 9:05 pm ] |
Just curious but looks like stock rear shocks with aftermarket springs ?? |
Author: | KOdy [ Sun Nov 15, 2015 9:08 pm ] |
Attachment: 20151115_174014.jpg [ 52.17 KiB | Viewed 3091 times ] Klx450 ..ready for wireharness and fire it up.. |
Author: | KOdy [ Sun Nov 15, 2015 9:13 pm ] |
Author: | KOdy [ Sun Nov 15, 2015 9:16 pm ] |
Attachment: 20151115_174153.jpg [ 47.54 KiB | Viewed 3089 times ] Shift linkage detail |
Author: | KOdy [ Sun Nov 15, 2015 9:19 pm ] |
Author: | KOdy [ Sun Nov 15, 2015 9:23 pm ] |
Attachment: 20151115_174341.jpg [ 62.66 KiB | Viewed 3087 times ] These CroMo tabs helped my everywere. Front suspension Front Engine mount Shift linkage Exhaust mount |
Author: | KOdy [ Sun Nov 15, 2015 9:26 pm ] |
Author: | KOdy [ Sun Nov 15, 2015 9:28 pm ] |
canadian oddy wrote: Just curious but looks like stock rear shocks with aftermarket springs ?? Nope.. still have OEM spring and shocks.. |
Author: | canadian oddy [ Sun Nov 15, 2015 10:08 pm ] |
KOdy wrote: Your missing the lock nuts on the u joint bolts. Watch it cause they will back out. Yup, I know. Those rear shocks will hurt your back. By the way very very nice job on that machine. Looks awesome. Can't wait to read your ride report. |
Author: | liduno [ Mon Nov 16, 2015 6:22 am ] |
B S wrote: KOdy wrote: if it docent last i have a bearing carrier with a sprocket and brake disc that was in a odyssey at one time Do you have any pics of the center carrier that was in an oddy? Did it use the stock axles? |
Author: | go oddy [ Mon Nov 16, 2015 7:10 am ] |
More info on the rack and pinion too please. Looks very nice and I hope you post a video of it ripping .... Those engines sound awesome. |
Author: | KOdy [ Wed Nov 18, 2015 3:04 am ] |
Attachment: Screenshot_2015-11-18-01-02-11.jpg [ 29.18 KiB | Viewed 3053 times ] Begun work on an adapter to use a new trx450r rear calyper on the fl350r |
Author: | KOdy [ Wed Nov 18, 2015 3:15 am ] |
Attachment: 31iSFjt3tOL._SY400_.jpg [ 10.77 KiB | Viewed 3053 times ] 14" rack and pinion.. from a buggy. |
Author: | go oddy [ Wed Nov 18, 2015 7:04 am ] |
KOdy wrote: Attachment: 31iSFjt3tOL._SY400_.jpg 14" rack and pinion.. from a buggy. Thanks for the picture and info thus far. I have a couple more questions if you wouldn't mind. What buggy? What ratio? Where did you source it? Thank you |
Author: | go oddy [ Fri Nov 27, 2015 5:30 pm ] |
Upadtes? |
Author: | KOdy [ Sat Dec 12, 2015 2:06 am ] |
Author: | KOdy [ Sat Dec 12, 2015 3:33 am ] |
Attachment: Screenshot_2015-12-12-00-12-00.png [ 198.42 KiB | Viewed 2995 times ] Will try a new TRX450 brake caliper.. with this CNC base.. |
Author: | go oddy [ Sat Dec 12, 2015 8:37 am ] |
go oddy wrote: KOdy wrote: Attachment: 31iSFjt3tOL._SY400_.jpg 14" rack and pinion.. from a buggy. Thanks for the picture and info thus far. I have a couple more questions if you wouldn't mind. What buggy? What ratio? Where did you source it? Thank you |
Author: | bullnerd [ Sat Dec 12, 2015 11:17 am ] |
Spindle nose on that CNC looks massive! good stuff dude...more pics! |
Page 2 of 3 | All times are UTC - 5 hours [ DST ] |
