It is currently Sat May 04, 2024 2:17 pm
Post new topic Reply to topic  [ 114 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Sat Feb 10, 2018 12:21 am
This is the fuel cap assembly.
I did it this way because the racing fuel cell setups are to big. This tank is only 5" wide.
PostPosted: Sat Feb 10, 2018 2:47 am
Way to go. Looks nice.
PostPosted: Sat Feb 10, 2018 11:59 am
I second that. That turned out very nice. You have some awesome fabricating skills.
PostPosted: Sat Feb 10, 2018 3:20 pm
Well it's skillbilly stuff.
Some guys are very anal about their machine. Everything on it must be perfect according to them. I am more of a functional person. It don't have to win a prize, it just has to run. If you had a real close look at my machines you may not feel the same way, but they are functional and look reasonable. What is good enough for one person is not good enough for another guy. The way I see it is as long as it is safe and runs your good.
PostPosted: Sat Feb 10, 2018 10:52 pm
Great job Udo,well done.
Just thought I'd share some pics here that might help you out in the future?
I had to end up removing that rear Bumper tank from the ex spcled1 ac550Pilot for safety racing reasons.
So I made up another that fits over the trany area as my exhaust was shifted up vertically and to the RH side.
Had to max it out for Enduros as well.
Maybe can do the same on the Ody IF you ever need to and should yield around 20-21litres?
I made it with a sump,Pilot fuel sensor,vent barbs with one way valve and top/bottom barbs for fuel level sight indicator.
All works great.I chose Alu for it's light weight,no rust,no paint etc
Got my mate's shop to weld it all up,turned out great.
File comment: This is that bumper tank that was on it when I bought it.
PostPosted: Sat Feb 10, 2018 11:20 pm
Few more pics.
PostPosted: Sun Feb 11, 2018 12:09 am
Few more pics.
First: thx.
Second: I really like that bump tank idea. I think it is the best idea by far for fuel in my opinion. It is easy to build and install. When you talk about safety reasons I am azzuming you mean it would be an issue if you got rear ended. Yes I could see that as being an issue, but it is aluminum and won't create a spark and you could put fuel cell foam and/or a rubber bladder in it just like my race car had.
I really like your other tank the best, it looks pretty. But the fabrication looks like it would be a nightmare. I have run into that nightmare building my tank. If I was to ever do this again I think I would pass on my idea. Bumper tank the way to go. Quick and easy. I was actually going to go bumper tank but my "buddy" talked me out of it. That was stupid of me to even listen to him. Should have know better as we nicknamed him "beer poacher" and he had already had several beers.
Finished the install of the tank tonight. You will notice that I had to take a hammer to the side of my freshly painted tank. I could not install because when I welded the outer skin on, it would not clear the camber adjustment bracket. Then repainted.
Still have to 1) fuel lines 2) build fuel return check valve 3) shock savers 4) skirting 5) install front brake rebuild kit when it arrives and bleed front brakes
File comment: Beat the hell out of it with a hammer
PostPosted: Sun Feb 11, 2018 3:04 am
That's called custom fitting.
Really nice. I can't say that enough.
PostPosted: Mon Feb 12, 2018 4:37 am
Well I pretty much finished this project.
Finalized the fuel tank and fuel lines. Installed shock savers. Put side skirting on.
Still need to order the wrist restraints. Also I am still waiting for the front master cylinder rebuild kit. When it arrives will install, bleed front brakes and put on the front skirt that keeps mud out of the cockpit. When this is done I will post the final two pics. One before and one after pic.
It's good to go.
File comment: Fuel tank and plumbing. Will make another post on that check valve in the tech section.
File comment: Shock savers installed.
File comment: Still need to install front skirt
PostPosted: Fri Feb 16, 2018 1:23 am
Well that's it for this thread. Done.
Loose ends:
Wrist restraints on order from http://blueskyppg.com/index.php?main_page=products_new
This project would have been done a very long time ago if I had the stock fuel tank. I recommend that anyone should look for a stock unit instead of trying to build one. If you have to make one then I suggest you locate it at the very back of the machine like the Aussie did. Much much easier than trying to shoe horn one into the stock location.
File comment: BEFORE
File comment: AFTER
PostPosted: Fri Feb 16, 2018 9:56 am
Job well done sir! You make it look to easy. :-)
Once all that snow melts I'll be looking forward to the first ride report. As you drive past the old crash site be sure to flip the bird!!! Will this buggy now be your #1 ride? I know you already have 2 of them for yourself and brother. It would be fun to have all 3 of them out together.
PostPosted: Fri Feb 16, 2018 2:29 pm
No to the #1 ride -- -- I don't like the seat in this one
Flip the bird as I ride by old crash site -- -- No to this one as they have now posted a full time guard on the bottom of that road. No one can get up there anymore. He parked a motorhome right across the road. This happened very soon after my accident. I am pretty sure they were worried about law suits. The way I see it is that we are all big boys. If you F up to bad for you. No cryin or suein. Man up.
PostPosted: Fri Feb 16, 2018 8:02 pm
That looks really nice. I know it has to feel good to not have ur ride smashed up every time u look in its direction.
Hope this helps put ur wreck a little farther in the rear view mirror.
I'm smiling for ya.
Way to go
Edd
PostPosted: Fri Feb 16, 2018 9:54 pm
I'm smiling for ya.
Way to go
Edd
I never see a wreck as a bad thing to look at. In fact I actually look at wrecks with pride. I laugh like hell that I walked away and get to tell stories about it. That might sound strange to some. I kept all of the smashed rims and plan on possibly making tables out of them. More to talk about. I would only be upset if it was smashed beyond repair.
Registered users: Bing [Bot], FL670R, Google [Bot], Lanix
