It is currently Sun May 19, 2024 8:35 pm
Post new topic Reply to topic  [ 112 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Mar 08, 2019 5:39 pm
the other one to where the wire and blue wire was at. Don’t forget this is a rotax conversion buggy. I’m lost on it still. When the buggy is running if I press the start button that will shut
File comment: [googlemap][/googlemap] the other one to where the wire and blue wire was at. Don’t forget this is a rotax conversion buggy. I’m lost on it still. When the buggy is running if I press the start button that will shut
PostPosted: Sun Mar 10, 2019 6:10 pm
I am confused now also....
It looks like you don't have the Black/Brown hooked up to anything, clean cut.
Your going to need a meter to ring out the wires now that they are all cut and not labeled. It wont matter if it is a rotax swap or not, those wires serve the same purpose regardless of Engine.
Are you running any lights on the buggy?
PostPosted: Tue Mar 12, 2019 10:49 am
Winch mount ideas
PostPosted: Tue Mar 12, 2019 10:51 am
I figured out the wiring. On the start button you have a yellow red wire and a black white wire. Fl350 wire harness has 2 solid black wire. Connected one of the solid black wires to the black and white wire and worked
PostPosted: Tue Mar 12, 2019 10:55 am
Also on rotax wire harness I needed to run 2 wires from the kill switch and one goes to the white blue wire where the white/blue wire is on the coil. And the other wire connect to the white/blue wire I took off the coil.
PostPosted: Tue Mar 12, 2019 10:57 am
Hope this helps. I’ve been struggling trying to post. It always come up as an error when submitting the post but today it’s not.
PostPosted: Tue Mar 12, 2019 10:59 am
Black and brown wire isn’t needed for anything because a ran a new wire from the kill switch to the coil
PostPosted: Tue Mar 12, 2019 11:00 am
Trying to put winches on the front and rear but don’t know how I’m going to mount them. Anyone done this?
PostPosted: Wed Mar 13, 2019 8:58 am
I'm glad you got it sorted out and shared your findings here! :-)
PostPosted: Mon Apr 15, 2019 10:03 pm
Would anyone happen to know what screw cap I could use for farrs fuel cell cap for the oil resovoir? The one that came with the conversion kit is plastic and just using it only a few times is chewed up. Plastic threaded into metal isn’t so great. Any information on the thread type and size would be much appreciated. Thank you.
PostPosted: Wed Apr 24, 2019 9:33 pm
Looks like this forum is on its way out. Anyone have questions feel free to ask. I maybe be able to help.
PostPosted: Wed Apr 24, 2019 9:51 pm
Try facebook
PostPosted: Fri Sep 06, 2019 5:34 pm
Has anyone done power steering to there odyssey’s? I want to do one but don’t want to have any welding required due to already getting powder coat done.
PostPosted: Sat Sep 07, 2019 11:54 am
Methodical has done it on his 5 link. Google Search on this site.
PostPosted: Sat Sep 07, 2019 8:31 pm
Thank you
PostPosted: Sat Sep 21, 2019 5:55 pm
I know this thread is old, but do you have any idea what kind of money you have stuck into this project? I've been drooling over this build for awhile now and love the way it turned out. I'm on farr's website every other day looking through the kits and just haven't been able to pull the trigger yet. I've done some calculating on my own and got around the 9k dollar mark or so.
PostPosted: Sat Sep 21, 2019 7:45 pm
Hahaha well thank you. I put a lot of time effort and money into it but was all worth it. I’m even still doing just real REAL fine tuning on every little wire and line mounted a certain way that I like it. As well as side panels and a hood for it. I have no idea how much money was invested into it. Alls I do know is it was all worth it. And every extra step I did is definitely recommended. “Powder coating”. Really depends on what your looking for. Do you just want better control than the front suspension is a good idea. Great steering. If suspension is a concern and your doing stuff like jumping than rear suspension should be thought about. Rotax conversion is INSANE. The difference in power is no joke. I see some people with rotax conversions but no front end conversion which I think is nuts. Everyone who has done these conversions haven't regretted it. Decent amount of work but worth it.
PostPosted: Thu Sep 26, 2019 3:49 pm
Here’s a little update on “add ons” here and there. Side panels I seen on eBay. I purchased the kit from the seller. Extended side panels and a hood. All aluminum. Well the purchase was over 6 months ago and he sent me the side panels but no hood. Rlm145. Anyone know of him or purchased his aluminum kits? He won’t respond back to me. It been awhile now. I’m a bit concerned. Not to many honest people these days.
PostPosted: Mon Sep 30, 2019 11:45 pm
Yeah, really trying to get rid of the sketchy front end for sure, plus getting disc brakes is huge too. If I do anything, it will be the whole package like you did. Everything just looks so good together. Cheers!
PostPosted: Tue Oct 01, 2019 10:39 am
Yea once you receive the front end you will know it was worth it even before installing it.
PostPosted: Mon Oct 14, 2019 8:53 pm
A little update on everything. How’s everyone been? Received my hood the other day. Took awhile but glad I atleast received it.
PostPosted: Mon Oct 14, 2019 9:26 pm
Wow,looks great! Got video? :-)
PostPosted: Mon Oct 14, 2019 9:47 pm
dam that looks good. I would love to do a 670 swap, but I have my BV360 running so good right now. I have long traveled my front but I really would love to do the rear
PostPosted: Mon Oct 14, 2019 9:51 pm
Thanks. I’ll do a video soon. 670 swap is worth it. Trust me.
PostPosted: Fri Oct 18, 2019 1:16 am
Hey big boy, do you have a rand head on ebay?
Registered users: adnoh, Bing [Bot], CurtisR401, Google [Bot], hoser, Rppjr
