Everybody better start talking about that piston and plug -- RIGHT NOW !!
I don't hear one peep about it here. Why is that ??
It's clearly telling a story -- at least to me it is.
Lets start at the beginning and Redskinman comments:
1) Pilot ran great for two days with no problems.
2) On my last ride of the day Friday I could tell it did not have the top end and the power that it previously had
3) Before I started tearing it apart I did a radiator pressure test to make sure the head gasket did not blow and it passed with flying colors.
4) For those of you that don’t know I am running a 400 cylinder with a sleeve from LA sleeve bored out to take CR 500 piston,currently running 89.50 mm
Here is how I see it:
1) Machine ran great for two days so there is no fn way there was anything wrong with that
Engine before he left the house.
2/3) On the last day of riding he noticed a power drop and did a rad pressure test -- it passed he says.
He also did a compression test and of coarse it failed.
4) He is running a CR500 pilot -- that means this is a kick azz Engine and putting out some power.
Now lets look at that piston and sparkplug because there is a lot of info there.
There is only 5 things that would cause a piston and plug to look like that in my opinion.
1) timing
2) fuel additives
3) leaking coolant water into combustion chamber/ over heating
4) jetting and lean out
5) detonation
We can discount #1 because our machines are keyed and there is no adjustment on timing.
It's possible that #2 is relevant because we have no idea what kind of fuel he ran.
We can discount #3 because he said he did a pressure check and it passed. If he was going up a dune and not gaining but working the Engine hard I would say it over heated because no air flow through rad but that is not the case here as he said he was chasing others at full throttle.
It's possible that #4 is a culprit but it ran good for two days so I will take a pass on this one. Did you look at the carb and verify no jet came loose or fell out ??
It's a possibility that #5 could have happened because we don't know what kind of fuel he was running and secondly he was out there for three days which means he fueled up several times and may have put some shyte fuel in by accident.
It you look at that piston I see detonation signs. That piston got real hot and the aluminum started to melt and flake off and it deposited on the sparkplug. If he would have run it any longer it would have holed the piston. Detonation will also bust a ring, especially on a kick azz Engine.
Just my opinions CO
