800cc Engine choice http://pilotodyssey.com/PO/viewtopic.php?f=5&t=19589 |
Page 1 of 1 |
Author: | Sandpilot [ Sun Nov 10, 2019 8:21 pm ] |
Post subject: | 800cc Engine choice |
Getting parts together for an Engine swap. What are your thoughts between..... 2001 RMK 800 Or 2005 ski-doo summit 800 |
Author: | liduno [ Sun Nov 10, 2019 8:44 pm ] |
Post subject: | Re: 800cc Engine choice |
Does the 05 has reverse? I think I remember seeing that you could mod the 01 to run in reverse, like the newer stuff. |
Author: | Sandpilot [ Sun Nov 10, 2019 8:48 pm ] |
Are you meaning reverse rotation or reverse gear? Neither sled has reverse gear. |
Author: | liduno [ Sun Nov 10, 2019 11:17 pm ] |
Sandpilot wrote: Are you meaning reverse rotation or reverse gear? Neither sled has reverse gear. Pretty sure I read you can modify the 01 to run in reverse. All the parts are said to be readily available. |
Author: | liduno [ Sun Nov 10, 2019 11:21 pm ] |
Just did a quick google search on ''2001 RMK 800 reverse kit'' and it looks like you can do it either way You can go with reverse rotation or a gear box mod. |
Author: | nitrosport_5 [ Tue Nov 12, 2019 8:13 pm ] |
Cant go wrong with a skidoo. Check the width of both and pick the narrowest one. That's where you are going to run into clearance issues. Iirc the RMK is going to be wider. What are you putting it in? Pilot or Odyssey? 800cc is quite a bit if you are going to be running through the stockgearbox. It will run quite a while if you are nice to them. |
