It is currently Sun May 12, 2024 3:37 am
PostPosted: Mon Nov 25, 2019 9:38 am
These are the drawings for all the components of my rotax Engine mount
M1A.PDF [59.36 KiB]
Downloaded 407 times
M2A.PDF [57.61 KiB]
Downloaded 337 times
M3.PDF [59.51 KiB]
Downloaded 369 times
M4.PDF [59.89 KiB]
Downloaded 348 times
M5.PDF [61.61 KiB]
Downloaded 343 times
M6A.PDF [57.94 KiB]
PostPosted: Mon Nov 25, 2019 9:41 am
more
M7A.PDF [56.89 KiB]
Downloaded 359 times
M-BUSHING.PDF [83.95 KiB]
Downloaded 317 times
SUPPORT MOTEUR ROTAX.PDF [910.34 KiB]
Downloaded 370 times
PostPosted: Mon Nov 25, 2019 11:22 am
Thank you sir. Sad to see you leaving the business. I'm sure you've heard that enough though.
Are you going to stick around and tinker on your personal machines?
PostPosted: Mon Nov 25, 2019 3:54 pm
Could you please post a drawing of the power steering plate you designed?
PostPosted: Thu Nov 28, 2019 10:12 am
pilot powersteering mount
PostPosted: Thu Nov 28, 2019 9:38 pm
this is great that he is willing to share his designs with us
PostPosted: Thu Nov 28, 2019 11:58 pm
Would you consider posting your custom gas tank designs, and also the FL400 rotax mount? They are fantastic!
Registered users: Baidu [Spider], Bing [Bot], Google [Bot], Gootjr
