PilotOdyssey.com
http://pilotodyssey.com/PO/
FL350 Restore x 3
http://pilotodyssey.com/PO/viewtopic.php?f=5&t=20769
Page 1 of 2
Author:  GarlicGreg [ Tue Jul 06, 2021 2:08 pm ]
Post subject:  FL350 Restore x 3
Here is the start of my project. Picked up the first batch of parts from the powder coater. My plan is to set up an assembly line and document my progress over all and with sub-assemblies. This pic was from awhile ago. I'm going to catch up with my posts.
Author:  GarlicGreg [ Tue Jul 06, 2021 4:58 pm ]
Post subject:  Re: FL350 Restore x 3
Here is a sampling of some of my my NOS parts stash a foot tub a fender and steering column side cover pulled from storage.
Author:  GarlicGreg [ Tue Jul 06, 2021 5:02 pm ]
I was able to source new ball joint boot rubber from a Honda JDM car. It is the same part number as the NLA Odyssey ones. I got them from the UK.
Author:  GarlicGreg [ Tue Jul 06, 2021 5:07 pm ]
NLA front bumper rubbers.
Author:  GarlicGreg [ Tue Jul 06, 2021 5:12 pm ]
Front bumper repair. Before and after.
Author:  GarlicGreg [ Wed Jul 07, 2021 3:34 pm ]
I stripped down my air guides, reconditioned the rubber, powder coated the metal and re-riveted them back together.
Author:  Kuma [ Wed Jul 07, 2021 3:58 pm ]
looking good, don't make it so nice you won't want to go out and enjoy it!
Author:  GarlicGreg [ Wed Jul 07, 2021 4:25 pm ]
I'm building this one to sell. I have 6 others to ride!
Author:  GarlicGreg [ Thu Jul 08, 2021 1:45 am ]
NOS axels
Author:  GarlicGreg [ Thu Jul 08, 2021 1:51 am ]
Recoveted seat with red stitching.
Author:  GarlicGreg [ Fri Jul 09, 2021 12:07 am ]
Assembly line.
Author:  GarlicGreg [ Sat Jul 10, 2021 1:32 pm ]
Refreshed transmission with new seals and bearings.
Author:  GarlicGreg [ Sat Jul 10, 2021 1:36 pm ]
Cables and wiring hung, ready to place transmission.
Author:  GarlicGreg [ Sat Jul 10, 2021 1:40 pm ]
New bearings and seal for axel carriers.
Author:  canadian oddy [ Sat Jul 10, 2021 2:02 pm ]
Very Very Nice
You're gona give CurtisR401 a run for his money.
It's gona be a toss up for first place but I think you got it.
Since you got all NOS stuff that thing should be in a show room.
Contact Honda.
I bet they pay the most.
Author:  GarlicGreg [ Sat Jul 10, 2021 3:49 pm ]
Thanks. I might just put it one of them on a pedestal in my man cave. Definitely will be too nice to drive.
Author:  GarlicGreg [ Sat Jul 10, 2021 3:53 pm ]
Measured brake disc. Plenty of meat left on it. Cleaned it up an Ceracoated the inner part.
Author:  canadian oddy [ Sat Jul 10, 2021 6:33 pm ]
Use some light thread locker (blue) on that big disk nut.
I have had them come lose.
Author:  GarlicGreg [ Sat Jul 10, 2021 6:50 pm ]
Yup good call! I've got the manual and it indicates that and torque spec. I had to source a 36mm wrench that would allow me to get the torque wrench at 90⁰ to properly seat it. Also manual says to use motor (( Internal Combustion Engine ? )) oil on the lock nuts that hold the brake disc on. I'm following manual religiously on wear specs, torque, lube and threadlocker application.
Author:  GarlicGreg [ Sun Jul 11, 2021 2:18 am ]
Tested then polished the shock bodies, powder coated the springs and installed new bump stops. The only thing that bothers me is the plastic spacers between shock bodies and springs are a little rough in a couple spots, not perfect but I can't find any perfect ones.
Author:  GarlicGreg [ Sun Jul 11, 2021 2:21 am ]
Brake backing plates got powder coated. All new brake hardware.
Author:  GarlicGreg [ Sun Jul 11, 2021 2:24 am ]
New rubber on the fuel tank skid plate.
Author:  GarlicGreg [ Sun Jul 11, 2021 5:01 pm ]
Test fitting parts. It's like you build it 3 times by the time you're done. Assemble, discover an issue, take apart, fix, test fit, disassemble then reassemble with proper fasteners, lube, locktite and torque.
Author:  CurtisR401 [ Mon Jul 12, 2021 1:42 pm ]
canadian oddy wrote:
Very Very Nice
LOL :-)
I would have to agree, you got me beat! Great work and they are sure to be beautiful machines when completed. Keep up the good work I am looking forward to seeing them completed.
Cheers, Curtis
Author:  fully [ Fri Jul 16, 2021 12:12 pm ]
im all for restoring, but I hate garage queens..they look nice but man you got to drive them..
https://www.phpbb.com/
