Rotax 582 http://pilotodyssey.com/PO/viewtopic.php?f=5&t=8173 |
Page 7 of 8 |
Author: | King Kx [ Sun Mar 20, 2011 9:20 am ] |
Post subject: | Re: Rotax 582 |
Nice, looks like it will have some killer bottom end torque! Looks like it is missing the MA plate for the trails. |
Author: | go oddy [ Sun Mar 20, 2011 9:56 pm ] |
King Kx wrote: Nice, looks like it will have some killer bottom end torque! Looks like it is missing the MA plate for the trails. gonna pimp it out with the big chrome plate bracket... it will weigh 20 lbs... |
Author: | King Kx [ Mon Mar 21, 2011 7:56 pm ] |
Looks like you will need it on the front to keep the front end planted! How is it on the top end? |
Author: | go oddy [ Mon Mar 21, 2011 8:19 pm ] |
King Kx wrote: Looks like you will need it on the front to keep the front end planted! How is it on the top end? Have not had it open yet... seems to pull hard once it kicks in... I think I can still go fatter on the main jets too... I know I should start fat and work down but I am already much fatter than the sled had to start... |
Author: | King Kx [ Mon Mar 21, 2011 9:47 pm ] |
In the many sled motor (( Internal Combustion Engine ? )) conversions that I have done, I have always found that I needed to substantially increase the main jet size when compared to what it had when it was in the sled. I used to try and make them spot on, now I just run them fat, there is still plenty of power for the trails even when they are good and fat, running 900-975 egt's. |
Author: | go oddy [ Tue Mar 22, 2011 7:18 pm ] |
I am at 480 mag side and 460 pto and she can still take more... I love this thing... Thanks for the info King... I was thinking I had something off... because the sled runs in the cold and without air filter I figured I would have to bring the main down in the Pilot with air filters and warm weather but NOOOOOOOOOOOOOO! Regards |
Author: | go oddy [ Wed Mar 23, 2011 4:50 pm ] |
tried some 22 inch tires on it... I do not prefer them... I will throw 24 or 25 on ...my wife loves the burnout... she is always trying to get me to smoke any and all tires... front wheels, rear, forward or reverse |
Author: | go oddy [ Wed Mar 23, 2011 5:47 pm ] |
At one point I was at the botton clip on the needles and boy did I have a hard time getting the cable out later.. the needle was so high the cable had to be perfect to clear the cut in the holder.... my fingers were killing me from holding those damn springs back.... More to come! |
Author: | go oddy [ Fri Mar 25, 2011 6:13 pm ] |
The wife drove it today... maybe a bad idea? she says it is a death trap.. I told her others have built much more powerful and quicker buggies, and she asked "do you think telling me this is helping?" LOL she thinks I am crazy any whoooo.... she drives quite well though... Here is a SALUTE to FAMILY FUN! Regards |
Author: | nitrosport_5 [ Fri Mar 25, 2011 10:55 pm ] |
that thing sounds great. Nobody else wants to get in my 570 ody. Im not going to complain though, less idiots to break it and more seat time for me! |
Author: | go oddy [ Wed Apr 06, 2011 8:54 pm ] |
nitrosport_5 wrote: that thing sounds great. Nobody else wants to get in my 570 ody. Im not going to complain though, less idiots to break it and more seat time for me! I am still working out the bugs to this build so it is just better if the seat stays ready for me as well... no injuries needed... need to find so new rear tires.. I would like to find so 23s that use a 10 inch rim... Still looking |
Author: | nitrosport_5 [ Wed Apr 06, 2011 9:09 pm ] |
at Rocky Mountain http://rockymountainatv.com i came up with 3 different tires that they offer in a 23x10-10 size. The Kenda Bearclaws being the cheaper ones. The ones on my ody are 22x12-10's for reference. http://www.rockymountainatvmc.com/typeD ... s&sortBy=3 |
Author: | go oddy [ Thu Apr 07, 2011 9:29 pm ] |
nitrosport_5 wrote: at Rocky Mountain http://rockymountainatv.com http://rockymountainatv.com i came up with 3 different tires that they offer in a 23x10-10 size. The Kenda Bearclaws being the cheaper ones. The ones on my ody are 22x12-10's for reference. http://www.rockymountainatvmc.com/typeD ... s&sortBy=3" .".. Thank you for the info.. you can be my research man anytime!... weak Top Gun reference Regards |
Author: | go oddy [ Mon Jan 09, 2012 7:37 pm ] |
Well I finally did what King KX rec long ago... I took my silencer that was originally for a KX 500 and modified it.. I was having heat issues with the old one after WFO for a bit... Now I cant keep my foot into it for long at all. I gutted the old shell... Bought a 1 3/4 ID exhaust pipe 18 inches long... this is a little larger than the exit of the sled expansion chamber... drilled a million holes in it ... wraped it in packing and placed in the old FMF outer package... It is a completely different machine now... and heat is... so far way down on pulls.. but I cannot keep my foot on the gas for longer than a few seconds... run out of real estate quick.... Thanks KING KX... great tip... shouldve done it long ago... G.O. |
Author: | King Kx [ Wed Jan 11, 2012 9:08 pm ] |
Glad your getting it all figured out. Working the bugs out takes longer than the actual build sometimes. Now you just have to get it registered and come out to play! |
Author: | go oddy [ Thu Jan 12, 2012 5:52 pm ] |
King Kx wrote: Glad your getting it all figured out. Working the bugs out takes longer than the actual build sometimes. Now you just have to get it registered and come out to play! Thanks again to all that have been a help.. advice wise or kind comments... I am glad that I am getting the bugs out.. but if I was to do it again I would make the transplant without changing the carbs at first... trying to get the carbs dialed in and not knowing if the exhaust was holding it back ( it was) or if it was the intake (filters air tubes) etc.. all at once makes it a second guess game.. try this and second guess it etc... It has been fun and I will do another for certain.... but having the unit as stock as possible on the swap would have taken a lot of the guess out of it... and dare I say EFI next swap.... I am now in search of a Quadzilla... always wanted a 500 2 smoke quad and now I need to find her... Regards to all |
Author: | go oddy [ Sat May 12, 2012 9:58 am ] |
Hello I have to go back and replace all the pictures to this post that were lost in the hack... Update... I moved the rad up behind my head and lowered the gas tank .... I did this because of cooling issues and to give just a bit more protection the the gas tank... It cools very well now and most trail time the fan stays off and under full use I turn it on via toggle (no temp assist yet)... I am thinking of this but just have not done it yet... This Pilot handles like a dream even with the Engine sitting a little higher than most desire and the TM38 carbs now with the rad change are a breeze to setup... I love these carbs... |
Author: | King Kx [ Sun May 27, 2012 10:37 pm ] |
You get this trail ready yet? October MTN is calling.. |
Author: | go oddy [ Mon May 28, 2012 6:38 pm ] |
King Kx wrote: You get this trail ready yet? October MTN is calling.. I am so close... give me a date after the week of june 2-the 10th weekend and I am in .... regards |
Author: | go oddy [ Sun Oct 07, 2012 8:03 pm ] | |||
Post subject: | Re: Rotax 582 | |||
some more of the Pilot with wheel locks
Author: | go oddy [ Sun Oct 07, 2012 8:06 pm ] | ||
the dc long bracket... Thanks for the brackets..... I needto finish this project so I can pull it apart and paint and detail the whole bug...
Author: | go oddy [ Sun Oct 07, 2012 8:12 pm ] | |||||
Post subject: | Re: Rotax 582 | |||||
Man have the filters been moved and located and relocated....
Author: | nitrosport_5 [ Sun Oct 07, 2012 8:48 pm ] |
Where do you find those intake hoses at? And are they attached to the carbs direct? Id like to get somthing like that to move my filters up higher... Although my filters wont ever be dirty at the rate im going |
Author: | go oddy [ Sun Oct 07, 2012 10:00 pm ] |
nitrosport_5 wrote: Where do you find those intake hoses at? And are they attached to the carbs direct? Id like to get somthing like that to move my filters up higher... Although my filters wont ever be dirty at the rate im going I cut the sled air box up and used the rubber mounts from it that mounted to the sled carbs... I attached the rubber intakes to the hose with 2 part epoxy and it has worked out very well... sorry it took my a bit to find the place I purchased the tubes from... here it is http://www.mb-supply.com/ |
Author: | go oddy [ Mon Oct 08, 2012 9:56 am ] | ||||||
Post subject: | Re: Rotax 582 | ||||||
some of the donor sled.... Im just trying to go through this project post and replace a lot of what was lost in the arse hackery
Page 7 of 8 | All times are UTC - 5 hours [ DST ] |
