PilotOdyssey.com
http://pilotodyssey.com/PO/
fl350 LT and sled motor (( Internal Combustion Engine ? )) PIC HEAVY
http://pilotodyssey.com/PO/viewtopic.php?f=5&t=9382
Page 1 of 4
Author:  jwhill [ Tue Jan 31, 2012 7:26 pm ]
Post subject:  fl350 LT and sled motor (( Internal Combustion Engine ? )) PIC HEAVY
I have been lurking on here for a while now as I had a 1979 fl250 about 25 years ago and a Pilot in the early 90's. My buddy just got a new 4x4 artic cat and wants me to ride so........good reason to build a fl350. TRX 450R front and a Rotax 470. Will post pics as we build.
this is the first setup on the front , to wide and didn't like it haning off the front like that
This is more like it
steering setup (-0- bumpsteer)
Didn't trust the flag on the spindle so my buddy made these up, works great and very strong
all tacked up, will round all the brackets after we weld it all up
Rotax and cooling
seat and pipe
Author:  davidafco [ Tue Jan 31, 2012 7:34 pm ]
Post subject:  Re: fl350 LT and sled motor (( Internal Combustion Engine ? )) ((starter motor (( Internal Combustion Engine ? )) or a fan motor (( Internal Combustion Engine ? ))?)
Nice. Will be following for sure.
Author:  jwhill [ Tue Jan 31, 2012 7:37 pm ]
davidafco, I see your in Cincy, this is in my shop in Fairfield.
Author:  davidafco [ Tue Jan 31, 2012 7:53 pm ]
Crap ,, never noticed you was Cincy,,lol I should stop by sometime and check it out in person.
Author:  nitrosport_5 [ Tue Jan 31, 2012 9:33 pm ]
Looks great. What is the radiator off of?
Author:  jwhill [ Tue Jan 31, 2012 10:36 pm ]
artic cat atv, fits a few different models, 500 - 800cc.
Author:  fully [ Wed Feb 01, 2012 9:26 pm ]
looking good..i am in the middle of doing a 450r conversion
Author:  hoser [ Fri Feb 03, 2012 2:51 pm ]
Nice build, you will love the torque that Engine will make, your thumb will not like those carbs, if you switch over to the watercraft carbs the thumb pull will be a lot less.
Zoom zoom ! :-)
Author:  Fatcat [ Fri Feb 03, 2012 5:08 pm ]
l
Author:  jwhill [ Tue Feb 07, 2012 3:12 pm ]
Got more done
Author:  DMoneyAllstar [ Tue Feb 07, 2012 4:59 pm ]
Nice! That pic from the front looks awesome.
Author:  Randman [ Tue Feb 07, 2012 5:05 pm ]
I like the aluminum cover that replaces the 2 plastic halves for the steering column. You should make some up and sell them!
Author:  jwhill [ Tue Feb 07, 2012 5:29 pm ]
The cover is made of sheet metal, we did that because we moved the steering column up for more room.
Author:  rarerat [ Tue Feb 07, 2012 5:59 pm ]
Very nice work!!
Author:  jwhill [ Fri Feb 10, 2012 8:54 pm ]
made air box out of aluminum
got muffler on
made mount for electronics
Thinking of a dash with tach, 2 egt's, volts and water temp.
Author:  nitrosport_5 [ Fri Feb 10, 2012 10:49 pm ]
what tach are you using? how will you wire it? ive tried forever to find a tach to work with my sled eng. progress looks excellent! i may borrow the way you mounted the gas tank and oil tank!
Author:  fully [ Fri Feb 10, 2012 11:07 pm ]
that equus is the same tach that i have been thinking about. pretty sure all you need to do is wrap the green wire around the plug wire
Author:  nitrosport_5 [ Fri Feb 10, 2012 11:52 pm ]
Happen to have a part number?
Author:  fully [ Sat Feb 11, 2012 12:19 am ]
no i don't. i know recognize it from the pic. same one canadian tire sells. $80 i think is what they want for it
Author:  jwhill [ Sat Feb 11, 2012 12:26 am ]
I'll get the part number, I run it on my golf cart with a briggs v-twin, you can run the green wire to the coil or it has a inductive pickup that clamps to a plug wire.
Author:  jwhill [ Sat Feb 11, 2012 12:32 am ]
The part number is 8068. Also have a new winch (promark 2500 lb.rope), and the fenders came in today as well. We will be making removable side panel as well as a hood. They will be fastened with dzus fasteners.
Author:  nitrosport_5 [ Sat Feb 11, 2012 1:07 am ]
Thanks for the number. Will you be using the green wire to the coil or the inductive pickup?
Author:  jwhill [ Sat Feb 11, 2012 1:29 am ]
Green wire
Author:  jwhill [ Sat Feb 11, 2012 1:31 am ]
I cannot take the credit for the fab work as my good friend Bob Parrott has done 90% of the fab work, he is very talented.
Author:  nitrosport_5 [ Sat Feb 11, 2012 3:19 am ]
jwhill wrote:
Green wire
thanks. be sure to keep us posted how it.works. i will for sure be watching. you guys have done good work. keep it up
Page 1 of 4 All times are UTC - 5 hours [ DST ]
https://www.phpbb.com/
