It is currently Tue May 14, 2024 8:01 pm
PostPosted: Sat Feb 18, 2012 10:09 pm
Well guys i finally got it...My very own fl350! :D Im very happy i found one but now its time to make it run and do all the other stuff that needs to be done to it. now as you seen in the title it says something about being 4wd...some say its impossible..some say it cant be done..i beg to differ. Please take a look at the link below.(scroll to the bottom of the page to see the last picture of the motor (( Internal Combustion Engine ? )) and the 2 diffs.)
http://www.lltransmachinery.com/ATV,UTV ... ential.htm
Now if you see...its farily simple and that it can be done. well maybe it can...anyways back on topic here, My goal here is to make my fl350 frame 4x4...now due to my money problem at the moment..its not going to be easy but ill do my best on trying to update as often as possible. My plan is to take and mount the front diff in the front of course, then take the steering and the a-arms off the atv and weld them to my frame.(This sounds great in my head).after that is done ill do the same to the back and mount the motor (( Internal Combustion Engine ? )).then ill just have to some how wire up all the odyssey controls and the shifter and all that good stuff. this may take a long time to do but i believe it can be done!!
Thanks to the people who support my idea. :D
PostPosted: Sun Feb 19, 2012 5:37 am
Looks like a pretty cool idea! Will you be building a subframe underneath so the driveshafts and differentials can be protected by skid plates? It would also be like a body lift so you could clear bigger tires under the fenders. Looks like a nice drivetrain setup. Who manufactures it? Is it good quality? What's wrong with the Engine in it now? Maybe you can get it running and ride it while you gather up all the parts you will need for the 4x4 conversion. They're still lots of fun in 2wd. Got any pictures of your FL350? I think that's a pretty cool idea. Keep us updated on what you do. Until then get it running and ride the heck out of it! ::-:
PostPosted: Sun Feb 19, 2012 7:53 pm
show have some pictures up tonight if i can figure out how :D
PostPosted: Wed Feb 22, 2012 9:05 pm
Nice man. Cant wait to see it all finished
PostPosted: Sat Feb 25, 2012 11:12 pm
well guys after looking at my budget on this- the 4wd isnt possible at this point but im thinking about putting a snowmobile motor (( Internal Combustion Engine ? )) in it. i would post pictures but im not sure how.
also a little progress, i got the frame striped down and im starting to sand blast it but my sandblaster isnt that big. so it will take me a while.
Registered users: Bing [Bot], Google [Bot], hoser, JTurtle
