Rear Axle Seal Brake Drum Side http://pilotodyssey.com/PO/viewtopic.php?f=63&t=12951 |
Page 1 of 1 |
Author: | hoser [ Sat Oct 19, 2013 1:53 pm ] |
Post subject: | Rear Axle Seal Brake Drum Side |
Listed as not available but here is the info. 91203-918-015 DUST SEAL (40X62X7) Searched and found this 40X62X7 seal no idea if it will work someone will have to order and test. http://www.partzilla.com/parts/detail/a ... 56906.html If not research a seal that fits the following they all used the same seal 1976 ATC90 A BRAKE + REAR HUB 1977 ATC90 A BRAKE + REAR HUB 1977 FL250 A REAR BRAKE DRUM + REAR BRAKE 1978 ATC90 A BRAKE + REAR HUB 1978 FL250 A REAR BRAKE DRUM + REAR BRAKE 1979 FL250 A REAR BRAKE DRUM + REAR BRAKE 1980 FL250 A REAR BRAKE DRUM + REAR BRAKE 1981 FL250 A REAR BRAKE DRUM + REAR BRAKE 1982 FL250 A REAR BRAKE DRUM + REAR BRAKE 1983 FL250 A REAR BRAKE DRUM + REAR BRAKE 1984 FL250 A REAR BRAKE DRUM + REAR BRAKE |
