It is currently Sat May 11, 2024 2:37 pm
PostPosted: Thu Jul 09, 2015 4:41 pm
I apologize if this is already known but I couldn't find anything.
I wanted to run all new wires on my fl250 build and I needed the end that plugs into the CDI (Capacitor Discharge Ignition) box.(I upgraded from points so my stock harness doesn't have the plug.) It took me a while but I got the correct plug and pins. I hope this helps people with the points to CDI (Capacitor Discharge Ignition) conversion.
http://cycleterminal.com Has them for cheap.
6 pin 2.8mm - .110 Male and Female locking connector - Nylon Connector with Terminals
Terminals Fit wire size .6 - 1.3 mm (16-22 AWG)
Natural
Connector Set Male and Female - Set SC1106 Nt $3.00 each
Black
Connector Set Male and Female - Set SC1106 Blk $3.05 each
Registered users: adnoh, Bing [Bot], Garemie, Google [Bot], JMBalbiani
