PilotOdyssey.com
http://pilotodyssey.com/PO/
Pilot Trans CSI 2007
http://pilotodyssey.com/PO/viewtopic.php?f=72&t=3004
Page 4 of 4
Author:  MAS Racing [ Sun Nov 17, 2013 10:04 pm ]
Post subject:  Re: Pilot Trans CSI 2007
rmesser wrote:
Sorry it took me a while but I had to get out the old bearings and measure.
These are the 2 bearing that support the gear box input shaft on the FL400.
#16 on Hondas Parts diagram
part number 91007-HE0-004
Honda parts diagram shows it as a 62/32
standard 62/32 bearing measures 65mm OD , 32mm ID, and 17mm wide
91007-HE0-004 actually measures 65mm OD, 32mm ID, and 14mm wide
The stamping on the oem bearing is SC06A33 JAPAN PX NTN (very hard to read)
#17 on Hondas Parts diagram
part number 91008-HE0-000
Honda part diagram shows it is a 6007
standard 6007 bearing measures 62mm OD, 35mm ID, and 14mm wide
91008-HE0-000 actually measures 62mm OD, 35mm ID, and 12mm wide
The stamping on the oem bearing is SC07A08 JAPAN PX NTN (very hard to read)
It appears that both Bearings are thinner then the standard bearing.
All other gear box bearing appear to be standard bearings.
Thanks for the info.
Author:  hoser [ Sun Dec 15, 2013 8:28 pm ]
Bearing 91008-HE0-000 actually measures 62mm OD, 35mm ID, and 12mm wide part number 17 on this page http://www.partzilla.com/parts/search/Honda/ATV/1989/FL400R%20A/REDUCTION%20GEAR/parts.html
If you Google 35x62x12 you can find suppliers that list this bearing but it looks like you need to order a bunch ?
http://www.rpmbearings.com/bearing-skf- ... r-s-a-13-r
http://www.tradebearings.com/7007c-bear ... 58726.html
http://www.tradebearings.com/7908c-angu ... 52859.html
http://www.rpmbearings.com/c-r-35-x-62- ... f-bearings
Author:  hoser [ Sun Dec 15, 2013 8:31 pm ]
Part number on diagram
This is all the actual sizes of the bearings needed in the trans.
7 Collar, 28x32x11 ((Collar not a bearing)
11 Collar, 17x21x10 ((Collar not a bearing)
16 Brg,ball 32x65x14
17 Brg,ball 35x62x12
18 Brg,ndl 16x22x12
20 96100-62070-00 BEARING, RADIAL BALL (6207) 35X72X17
21 96100-62090-00 BEARING, RADIAL BALL (6209) 45X85X19
22 96140-63030-10 BEARING, RADIAL BALL (6303U) BEARING, RADIAL BALL (6303) 17X47X14
I put all the bearing dimensions after each bearing for future searching.
Author:  rmesser [ Mon Dec 16, 2013 10:40 am ]
Parts Diagram.
Author:  Kuma [ Wed Apr 17, 2019 10:41 pm ]
Just thought I would tie this post with my rebuild, pretty much identical failure. http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=18512&p=179470#p179470
Page 4 of 4 All times are UTC - 5 hours [ DST ]
https://www.phpbb.com/
