Its real easy to 'attach' pictures to your post here on PilotOdyssey.com, this is also called attaching attachments since you might want to attach a text document or a PDF file to your post.
Create your post and or if your replying to another post and want to add a attachment all you have to do is click on the
Browse or
No File Selected buttons located below the Submit button (RED arrow in my attached pic) then navigate to the item you want to attach to your post (picture, text file, PDF) select it then click Open, if you have more than one attachment you want to attach then click the Add The File button it will upload your attachment then allow you to select another attachment to be added to your post.
I have the setting set to where I think you can attach up to 8 attachments to each post then if you have more you want to attach you will need to reply to the post again and add more.
When your all done adding attachments and typing in your post you just hit
Submit like any other post and it will post your message with the attachments.
File comment: Here is where you can add a description to each attachment if you want.
Here is a tip, if your done typing up your post and you have just added your last attachment you can skip the Add The File thing and just hit the Submit button it will attach the attachment to your post same with if you only have one attachment you can just hit Submit and skip that annoying popup box that tells you your uploading a attachment.
If you add say 3 pictures to your post then decide you wanted to add a 4th pic no problem just click the Edit button (Blue Arrow) at the bottom of your post go back and attach the 4 picture.
Now see if you can figure out the Place Inline (Pink Arrow) option, I used it to place the pictures where I wanted in my post.
What happens if you accidentally attach the wrong file and you want to change it or remove it, if you already made your post use the Edit button then simply Delete the file and save your post or you can Delete the file you want to remove and replace it with the one or ones you want, I have accidentally attached the same file twice and had to go back and make the corrections, the Edit and delete buttons comes in handy for this.
I am sure by now you have figured out how to add text to an attachment if you wanted to.
Any questions problems comments please share with us.
If you cant attach a file and get a ERROR please make sure to notify me and let me know what the error is so I can research and hopefully correct the problem, I think I have the problem with BIG ASS pictures taken care of it will automatically resize them for you as you attach each picture.
