It is currently Tue May 21, 2024 8:25 pm
PostPosted: Thu Feb 28, 2013 4:20 pm
Well, just smoked my torque clutch and turns out these disks are discontinued. Mine are under spec.
Any alternatives out there? i know you can get the fiber disks aftermarket from EBC
22401-HE0-000 SPRING, CLUTCH
22201-HE0-000 DISK, CLUTCH FRICTION
22311-HE0-000 PLATE, CLUTCH
PostPosted: Thu Feb 28, 2013 5:53 pm
Are you sure they are discontinued? how did you smoke them? Any pictures? Are the springs in spec?
PostPosted: Thu Feb 28, 2013 6:06 pm
yup ordered from partzilla last night, got reply they are nla. I smoked them running 125hp through a trans meant for 40... lol. my plates are blue and the friction disks are under spec. all parts in my torque clutch are under spec.
pictures
PostPosted: Thu Feb 28, 2013 6:39 pm
I would try another supplier.. I just got a couple of sets of plates and I also picked up some EBC fiber plates and then used spacers to increase spring preload as my springs were under spec as well...
PostPosted: Thu Feb 28, 2013 7:05 pm
How did you determine the thickness of the spacer? To thin and not enogh pressure clutchs slip to offten. To thick and to much pressure and the clutch does not slip, putting nondesired torque on internal tranny part.
th springs do not fall out of spec because of ware but I assume being compressed and going through heat cyles over a period of time.
PostPosted: Thu Feb 28, 2013 7:13 pm
Whats the condition of your oil? What oil are you running?
I would recommend more frequent oil changes to get the tranny cleaned up, assuming you are not going to terat it apart. The cork face of the plates had to go someplace. the Steel plate should not wear to much as long you do not let the cork wear off the plates.
Make sure you soak the new EBC p[lates in oil before you install.
You could probably run the plates the way they are. If you get new EBC clutch plates and keep an eye on the condition of the oil, watching for contamination of worn EBC plates, you may be ok. Also space you springs like go oddy did.
Can you give us a idea of how your pilot reacted when you first noticed you had a problem please. That way we will have an idea if it ever happens to one of us.
What are you using for a new gasket on the clutch cover?
Sorry so many questions.
PostPosted: Thu Feb 28, 2013 7:17 pm
I have no idea about this brand but thought I would let you know if you do not already. I have a set EBC I bought supper cheap years ago. hopefully I will never need them.
http://www.ebay.com/itm/Ferodo-Clutch-P ... 16&vxp=mtr
Anyone ever use this brand?
PostPosted: Thu Feb 28, 2013 7:49 pm
viewtopic.php?f=1&t=11383
PostPosted: Thu Feb 28, 2013 9:36 pm
as far as oil changes, i have one good ride on this oil, plus a few rides around my shop so it shouldn't be too bad. my old cork plates still have some meat left on them so it didnt get to metal to metal.
If i do not find any plates, i will use the old ones as is with a spacer on the spring.
When they went bad, it was like a switch. It was okay was delivering the torque and probably slipping slightly and i wasn't noticing. then i went to launch it and it sounded like i was spinning the shit out of the tires... but there was no tire spin. Did it again and it was just slipping. Took it for a short spin down the flat and i could hear the basket around the plates rattling. not sure why it was. took the clutch cover off and it all smelt like burnt oil.
as far as the gasket, when i took the cover off it did not hurt the old gasket since it hasnt been together for long. the gaskets i used i bought from a member here.. i want to say it was you? i bought trans gaskets when i was rebuilding the alabama pilot.
http://www.ebay.com/itm/Ferodo-Clutch-P ... 16&vxp=mtr" ."..
I bought a set of EBC and a set of those. was going to compare them. I will post pics when they arrive.
PostPosted: Thu Feb 28, 2013 11:17 pm
Oh ya I did sell you the gaskets - forgot about that. You'll have her back together before long.
PostPosted: Mon Nov 18, 2013 12:02 pm
More clutch plate and spring discussion http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=13073
PostPosted: Mon Nov 18, 2013 3:30 pm
I've been using the ferodo clutch fibers ever since I started this thread and they have held up fine. used then old plates, soaked the new fibers in oil, and installed spacers on the springs. just used standard washers that ibenlarged the center hole to fit around the posts in the clutch pack.
this seems to be working great, not any excessive slippage. I am still able to get wheelies with my 670 :)
PostPosted: Mon Nov 18, 2013 4:22 pm
Thanks for the update, the above ebay links were dead did some searching found some info to document here.
The old ebay link said Ferodo-Clutch-Plates-for-1989-1993-Honda-FL400-Pilot-4-Wheeler-NEW so I Googled it and found another link on ebay and found the following pictures, in the one pic I searched for numbers and found more info on these plates.
First I searched for ferdo fcd0182
http://www.ferodoracing.com/catalogue/detail_clutches.php?cat=clutches&code=FCD0182
Found some cross reference numbers EDIT Cross reference numbers need confirmed!
EBC CK 1221
NEWFREN .F.1687
The ECB number looks like it fits
This listing is for an EBC CK1221 clutch kit to fit a Honda GL 1000 K1 (Up to E.No:-2002383) (77). ????
PostPosted: Mon Nov 18, 2013 4:38 pm
I disagree with the EBC cross reference. I believe it should be EBC CK1234.
PostPosted: Mon Nov 18, 2013 4:56 pm
I believe you are correct. the ferodo ones I am using are the FCD0182. they measured out the same as the ebc kit.
PostPosted: Mon Nov 18, 2013 6:31 pm
Why do you disagree with the cross reference, I am only going by what they provided, does not mean its right, this whole parts chase thing is trial and error lol Hopefully someone can confirm then update this thread I know others will need them sooner or later.
Still need to figure out a application so we can find the steel plates and so we can find some more springs :-)
Thanks for the help!
PostPosted: Sun Dec 08, 2013 9:37 pm
http://www.m-and-d.com/HON-22311-HE0-000.html" ."..
I would give them a call and see if they have them before ordering. Just passing on info
PostPosted: Tue Jan 21, 2014 1:04 am
I just re-ordered these clutch plates from partzila a few weeks ago with another part order for the heck of it. I ordered 12. 3 arrived today with 9 on order from Honda. was told they should be in in a few days. so we will see if they really ship or not. strange I was told last year that they weren't available. would Honda have built more?
PostPosted: Fri Feb 28, 2014 2:23 pm
found out today no more plates all gone and discontinued. any body get any?
PostPosted: Fri Feb 28, 2014 6:06 pm
I got those 3 and then the order was canceled after about a month of backorder. sucks. but got 3 if I need a replacement . wish I would have got 4
PostPosted: Sat Mar 01, 2014 2:02 am
Did you order the 22311-GC4-730 clutch plates? If not they are an exact match and might still be available.
PostPosted: Sat Mar 01, 2014 3:53 am
no I did not. I did not know they were the same part
PostPosted: Sat Mar 01, 2014 2:56 pm
Thanks mass I will oder one in .
PostPosted: Sun Mar 02, 2014 3:18 pm
Mass, if you have one of those steel plates will you measure the thickness for me please.
If Anybody has a new Honda please do the same. I have "H",s number of 1.39mm
