It is currently Sun May 12, 2024 7:04 pm
PostPosted: Sun Jun 16, 2013 10:01 am
Looking forward to watching the build Joe!
PostPosted: Sun Jun 16, 2013 11:27 am
Good to see you got the Engine
I thout that was the singal carb intake he was going to send you
There ugly
PostPosted: Mon Jun 17, 2013 8:25 am
I like that Farr also paints his heads Chevy Red. Its a great color next to the aluminum and 'pops' in the Engine bay.
Good luck with the build!
PostPosted: Tue Jul 02, 2013 9:32 pm
any update?
PostPosted: Wed Jul 03, 2013 5:02 am
So that's what you did with the money i gave you for those j arms
Nice one ACE
Keep us all upto date on the build
Good luck
PostPosted: Wed Jul 03, 2013 9:16 am
Ace wrote:
I might have a problem with the upper coolant outlet, mine comes straight out towards the carb Instead of up out the top, I need to see if it will interfere with the BN carb..we will see.
Wow to much to many ideas..to bad I don't drink. Lol.
Joe
Wonder if the fitting on the right will work for re-directing that head coolant tube?? This is from a 670 and both parts are on evilBay for $15 + s/h. The part on the left will not fit your Engine (its for newer models), besides yours already has the horizontal pump cover. =)
http://www.ebay.com/itm/Ski-Doo-SkiDoo-Bombardier-Rotax-670-water-coolant-ports-/400407841203?pt=Motorcycles_Parts_Accessories&hash=item5d3a2ac9b3&vxp=mtr
PostPosted: Wed Jul 03, 2013 9:35 am
I hacked my own out of a big chunk of aluminum and hand tools
Wish I could have found that fitting on the right for mine lol, hope it fits.
PostPosted: Wed Jul 03, 2013 1:52 pm
Ace wrote:
Joe
Well heck there you go thanks. And Hoser that doesn't look too bad.
Nice job, so is that a 470? Just wondering how the single carb
And intake with different rotary valve timing works on it.
Thanks joe.
Mine is a 440
PostPosted: Wed Jul 03, 2013 2:44 pm
Joe
Thanks joe.
Mine is a 440
Oh ok, I guess it will be ok then. Thanks.
Joe.
Your timing will be controlled on the Engine side so if you use the 470 valve plate regardless how the manifold on the upstream side matches your timing will be correct, that is if you set the valve plate to the correct timing, follow me? I matched up my manifold to the intake openings as best I could so the total flow opening would be a straight smooth pipe no steps or notches (miss matching) between parts but again if you think about it its the surface on the Engine and the valve plate that controls the opening size shape and timing.
Get it running and dialed in I think you will agree you have more than enough power if not you can always go back and tweak it for more power in the future :-)
Read the factory manual see what it offers for different disc valves, figure out what you have and install to complement the disc you have, they offer a bunch of different disc for either low rpm or for rev I went with the low rpm settings on mine gives you more torque on the bottom end, try to adjust the intake timing on a piston port or reed cage Engine :-) you gotta buy new cylinders and modify each time you want to change it, that's the beauty of these disc valve engines....
PostPosted: Thu Aug 08, 2013 12:03 am
any update?
PostPosted: Tue Nov 26, 2013 10:14 pm
Any progress?
PostPosted: Wed Nov 27, 2013 6:02 am
Ace wrote:
B S wrote:
Any progress?
Ya a little,
I pulled the trans, figured nows the time to go through it.
I'm considering polishing the cases, lol.
Need to cut the frame so I can install the frame mod, then bolt that 470 in there.
Then get to that seadoo carb..
Next trans I rebuild I want to paint black looks better that way
The one on my pilot is black and looks so much better that way
