It is currently Thu May 09, 2024 11:56 am
Post new topic Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: ChrisV's fl670 build
PostPosted: Fri Apr 11, 2014 4:35 pm
i started fabbing my tank up. it should hold a little over 5 gallons. there will be a 8x3 sump on the right side for the pick up.
PostPosted: Fri Apr 11, 2014 6:01 pm
Looks good, do you think you need baffles to keep from sloshing around?
PostPosted: Fri Apr 11, 2014 10:23 pm
not really. the spun tanks don't have them, the stock tanks done have them, and its only 5 gallons. the sump will have a couple 1" holes draining into it, so they will act like a baffle to keep fuel in the sump when the fuel is low.
now would one hurt anything? No, and I may make one to go in it.
PostPosted: Fri Apr 11, 2014 10:28 pm
Looks good chris. May have to follow you and build myself a tank. Would be nice to have over 4 gal. Hell I'd really like 6 looks like there is room for a bit more if you made it straddle that bar. Although lots more work.
PostPosted: Fri Apr 11, 2014 10:33 pm
yea, and the way the pipe runs takes some room. I need to calculate the volume. the 1st tank I mocked up held 6.5 gallons. this one is 1" shorter. I may actually fab up another after the may ride. I have an idea that I want to try, but that will be revealed later.
PostPosted: Fri Apr 11, 2014 10:45 pm
Doh forgot about the pipe and muffler.
PostPosted: Sat Apr 12, 2014 1:21 am
lol haha
PostPosted: Sat Apr 12, 2014 1:23 pm
I didnt mean to insisuate you don't know what you are doing :-) , just making a suggestion, and yes I would think 1 " holes would keep the gas from sloshing away from the pick up. Good idea!
PostPosted: Sat Apr 12, 2014 1:43 pm
I didn't take it that way at all. Sorry if my reply was a little short
PostPosted: Sat Apr 12, 2014 2:24 pm
The LS trip is sneaking up on us, do you think you will have ole girl ready by then?
PostPosted: Sat Apr 12, 2014 3:01 pm
I'm doing my best. I'll order cables Monday and that should be all the parts.
PostPosted: Sat Apr 12, 2014 3:28 pm
Looks like you have your work cut out, we have another ride scheduled for a few weeks after this one so if not, maybe next trip
PostPosted: Sat Apr 12, 2014 8:01 pm
the fuel tank is fabbed minus mounts and the taps. I made the sump larger then I had originally planned. why not go for the extra quart of fuel. :-)
File comment: cutting out the sump.
File comment: hammer time!! it was too thick for my brake
File comment: sump welded up
File comment: my third hand. tacked on the 4 corners
File comment: test fit
PostPosted: Mon Apr 14, 2014 10:16 pm
Great job Chris,now go one further for safety sake.
Never liked the posi of fuel tank over exhaust,motor (( Internal Combustion Engine ? )) etc,incase of leak.
I would be installing a drip tray under the tank,with drain away tubes that exit to the ground.
You never know when you spring a leak,all it's all behind you,and you'll only find out when it's too late mate!Image
PostPosted: Mon Apr 14, 2014 10:21 pm
Never liked the posi of fuel tank over exhaust,motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) etc,incase of leak.
Its the dirver mate, not everyone drives like a bat outta hell bugs, heh heh!
PostPosted: Sat Apr 19, 2014 5:21 pm
I've been playing around with intake ideas but can't really find one that I like.
File comment: This set up would have two uni filters
File comment: This is the filter that d$alstar is planning to use.
PostPosted: Sat Apr 19, 2014 5:25 pm
And one playing around with my spool mate gun. Not to bad for the 1st try
PostPosted: Sat Apr 19, 2014 9:55 pm
Not bad at all!
Pics of your spool gun?
PostPosted: Sat Apr 19, 2014 10:08 pm
Spoolmate 185 on a millermatic 185.
PostPosted: Sat Apr 19, 2014 11:45 pm
Looks real nice crisv , it looks like it is starting to shape up well , hope to see ya at the dunes.
PostPosted: Sun Apr 20, 2014 10:04 am
I am trying to make this trip. it will be close for sure.
I still have to:
1. fab hoses
2. wire fan
3. mount CDI (Capacitor Discharge Ignition)
4. mount coil
5. wire it up
6. heat shield for seat
and I have about 4 days left in my schedule to work on it.
PostPosted: Mon Apr 21, 2014 5:13 pm
finished the filter housing. the K&N needs to be cleaned and oiled.
PostPosted: Mon Apr 21, 2014 5:23 pm
IS IT JUST A K&N OR DO YOU HAVE THE OTHER FILTER IN THERE?
IF YOU HAVE THE OTHER FILTER IN THERE I WOULD RUN THE K&N DRY WITH A PRECHARGER BAG OR PANTIE HOES OVER IT
PostPosted: Mon Apr 21, 2014 5:28 pm
Both filters are on it
PostPosted: Tue Apr 22, 2014 11:50 am
Awesome! Jealous...I can't weld aluminum (yet).
Registered users: Bing [Bot], Duneit, FL670R, Garemie, Google [Bot], Lanix, wyeeoddy
