It is currently Sat Jun 15, 2024 8:55 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 13, 2014 2:19 pm
MD_ODY wrote:
hoser,
Forgot to ask; you said the piston is 75mm, do I need to change the jets on the stock carb? I'm going to run it with a DG pipe, and may be 94C, but everything else is stock.
When ever swapping to a after market pipe I always go a few sizes bigger on the main jet and lower the clip on the needle at least one notch so it will richen up the mid range too, this is a starting point you need to monitor the jetting and verify its rich enough for the new pipe.
I doubt you will need to change jetting because of bore size alone.
PostPosted: Fri Jun 20, 2014 8:50 pm
hoser,
The motor (( Internal Combustion Engine ? )) came on Monday and I just opened it up today. That's some good packing! I'm going to keep it for the next time I ship a motor (( Internal Combustion Engine ? )) to you. This is going into the 84 frame off that I'm doing.
Quick question, what's the purpose of the nut above the spark plug?
PostPosted: Sat Jun 21, 2014 9:50 pm
Nut above the plug is extra clamping force on the head where the cylinder gets the hottest I think its the CR version of this Engine that was used on bikes had one on the intake side of the head also.
The spark plugs I installed was to plug the holes not sure if they are any good or not. :shock:
PostPosted: Sun Jun 22, 2014 4:55 pm
Thanks for that bit of knowledge, I couldn't find it anywhere. I bought new plugs for the motor (( Internal Combustion Engine ? )), so not too concerned.
