It is currently Thu May 09, 2024 7:44 am
 Post subject: Driven Clutch Puller
PostPosted: Mon Jun 19, 2006 8:03 am
Here's what I made to pull the driven clutch off my 350 Ody after 3 days of wrestling with the #*+@%^! thing. Tap threads into the 3 holes on the clutch boss face,then fit the puller & bolt it up. Around the collar are a series of holes to take some self tapping screws into the boss curved side for added purchase/load sharing. Screw in center bolt while tapping gently on bolt head.Use lots of spray & heat.
PS. The dodgey welding was due to puller also being used as abstract art lounge ornament :shock: Would you believe earthquake! :-) Baz
 Post subject: Re: Driven Clutch Puller
PostPosted: Wed Aug 02, 2017 6:32 pm
Nice work!!
