It is currently Sun May 19, 2024 1:37 am
Post new topic Reply to topic  [ 97 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Pilot fl500
PostPosted: Sun Feb 08, 2015 4:00 pm
B S wrote:
you will want one of these
http://www.ebay.com/itm/MIKUNI-SBN-SUPE ... d7&vxp=mtr
the chokes are crap on those carbs they don't pull fuel that's why everyone uses this
i would personally ditch the oil pump just remove it plus you know your fuel is properly mixed
I have it, but i don't know what it is for.
PostPosted: Sun Feb 08, 2015 4:18 pm
i don't need this, in my carb i have choke cable.
PostPosted: Sun Feb 08, 2015 9:05 pm
It's called a primer. They work really good. Here is how it works.
PostPosted: Mon Feb 09, 2015 4:37 am
I must drill my carb for install this?
PostPosted: Mon Feb 09, 2015 10:23 am
my choke works fine.
i removed the oil pump and run a premis at 32:1. maybe a little rich for some but plugs are cheap. I have yet to foul one.
you need to get a OEM manual for the skidoo it will have the wiring diagrams and plumbing diagrams. you must wire the skidoo Engine up to run.
here is a quote from my post on how i wired my 670
1. Rotax regulator red wire to 12v+ in run which would be the black wire at the pilot regulator or you could use the pilot black & white wire to the pilot CDI (Capacitor Discharge Ignition)
2. Rotax regulator Yellow wire to yellow wire on rotax stator
3. rotax regulator green wire to yellow wire on rotax stator
4. rotax CDI (Capacitor Discharge Ignition) black & white wire to ground to kill the Engine. i did this with the "off/run" switch. My machine runs in "off" i cut the wires originally going to the switch and soldered them together. I then run one end the switch to ground and the other to the stator on the rotax.
I used a 180F switch to turn my fan on and off.
SkiDoo 1991-1993 Formula Wiring Diagram1.pdf [83.66 KiB]
Downloaded 228 times
1997 SKI DOO WIRING DIAGRAMS.pdf [3.6 MiB]
Downloaded 217 times
MMR98V2A.pdf [460.97 KiB]
Downloaded 175 times
PostPosted: Mon Feb 09, 2015 1:30 pm
Ok, thanks.
Are You using original choke with cable? are You not using primer fuel?
PostPosted: Mon Feb 09, 2015 4:02 pm
i am using a seadoo choke cable and no i am not using a primer
PostPosted: Wed Feb 11, 2015 5:16 pm
The Engine run.
PostPosted: Wed Feb 11, 2015 5:49 pm
The Engine run.
Good for you as I purchased the same kit from FARR too but we have 18" of snow on the ground and it's about 20 degrees out side so I'm just collecting parts right now and waiting on the weather. Where in France are you located as my son-in-law is from TOURS(central France I believe)?
PostPosted: Thu Feb 12, 2015 1:28 pm
Hi,
I am very satisfied with FARR, he works very well.
I from VANNES in britany west france.
I know TOURS.
PostPosted: Thu Mar 26, 2015 1:25 pm
Ca avance!
PostPosted: Thu Mar 26, 2015 2:17 pm
Looking good. I'm so impressed with your fiberglass work on the fenders and side panels. I hope they hold up well. I wonder if they would be less resistant to chips I they were coated with rubber truck bed liner?
Why did you change to foot brake?
The sheet of steel or aluminum behind you seat needs some louvers to allow air flow, not very aerodynamic.
Keep the updates coming I enjoy watching your build.
PostPosted: Thu Mar 26, 2015 6:54 pm
Yeah great job on the glass.
Just wondering if those nets meet your racing requirements? They look like they wouldn't do much to stop anything.
Looking forward to seeing some racing video.
PostPosted: Sun Mar 29, 2015 3:22 pm
Hi,
Brakes on the foot, sheet of steel behind thenseat and the net are required for racing over here.
PostPosted: Mon Apr 13, 2015 12:18 pm
Finish!
PostPosted: Mon Apr 13, 2015 12:21 pm
Video
PostPosted: Mon Apr 13, 2015 12:25 pm
Suite
PostPosted: Mon Apr 13, 2015 4:11 pm
I'm bummed because the video won't play for me.
The Pilot on the other hand looks great. Nice work.
PostPosted: Mon Apr 13, 2015 4:25 pm
Man that's a nice machine. Great job. Looks awesome.
PostPosted: Tue Apr 14, 2015 9:13 am
Click on the link and download the video play it on your computer download/file.php?id=52865
PostPosted: Tue Apr 14, 2015 9:37 am
Nice work how much longer is it over stock?
PostPosted: Tue Apr 14, 2015 3:15 pm
Thank you.
PostPosted: Tue Apr 14, 2015 3:34 pm
Sounds like a skidoo sled to me! lol Sounds great!
PostPosted: Tue Apr 14, 2015 5:39 pm
Again, nice job French, you have some skills.
Would love to see some outside the car video.
Good luck racing.
When is the first race?
PostPosted: Thu Apr 16, 2015 2:54 pm
Thanks for your posts. The first race will be on may the 17th.
Will keep you posted.
