It is currently Sat May 11, 2024 4:12 pm
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jun 14, 2017 6:01 pm
about 9 to 10?
PostPosted: Wed Jun 14, 2017 6:51 pm
mcali2 wrote:
about 9 to 10?
9 to 10 will be fine!
You'll actually get to see my Ody for once!
PostPosted: Wed Jul 12, 2017 2:07 pm
Rand was that to be a 80.5 piston?
I forgot to order it and now I cant remember.
PostPosted: Wed Jul 12, 2017 4:08 pm
Hmmmm.....
I want to say it would be a 80.50mm but I'm here at work and the bottom end isn't here with me LOL so I can't just look. I though I remember the piston in the cylinder being 80.00.
Let me measure the piston tonight and I'll get back to you.
PostPosted: Wed Jul 12, 2017 11:06 pm
It's a good thing I double checked!
I went out to the garage and scrapped the top of the piston that is still connected to the rod. The part number is Wiseco Part number 533M08050 which is an 80.5mm. You will need to purchase an 81.00mm piston which is Wiseco part number 533M08100.
PostPosted: Sun Jul 16, 2017 12:01 am
ok thanks
PostPosted: Fri Aug 11, 2017 7:31 pm
Well I have bad news for me... The cylinder and piston and anything else I had were stolen. Sort of.... I put the parts on top of the sand bags at my home and the city cam and remove the sand bags.. they did not even notice the stuff on the pallet of bags. They said they will replace the parts but Im not convinced yet. I had to find them on line E bay. I can get you the trade any time you like.
PostPosted: Fri Aug 11, 2017 11:31 pm
Don't buy anything on EVILBAY!
I have a couple of cylinders here you can have. PM sent for my phone number.
PostPosted: Tue Aug 15, 2017 1:19 am
Mike,
I checked my cylinder stash and I have a cylinder that came out of Kolby's Ody and it is currently bored at a sloppy 80.5mm so you will need an 81mm piston. Of course you will need to have the cylinder bored to 81mm like your other cylinder as I mentioned before.
Let me know when you want to come by and pick it up.
PostPosted: Wed Aug 16, 2017 10:04 pm
ok. The city bought a cylinder 80.5 and new piston, new intake, new used reed cage and exhaust flange. I will use that stuff because they got the piston too.
PostPosted: Thu Aug 17, 2017 12:29 pm
WOW SHOCK AND AMAZEMENT!
That's good news! Ill start cleaning up the bottom end this weekend.
PostPosted: Thu Aug 17, 2017 1:39 pm
Wow is right, Congrats on getting this to happen. Shame there wasn't a few other hard to find items sitting on that pallet! :-)
PostPosted: Thu Aug 31, 2017 9:30 pm
I got all the parts in. I need to send out for work. I may go check with the local guy here tomorrow and see if he can do it. What was the limit of gap? .004 max? was that in the center or top when you take measurements? Frame is sanded down. Will be working on the tabs to mount some expanded metal on the bottom. Rand, how was the trip?
PostPosted: Fri Sep 01, 2017 2:32 am
I believe the specifications for the Wiseco piston is .0045" max. This will be measured on the bottom of the piston. 2 stroke pistons are actually tapered and are narrower on the top than they are at the bottom.
If you are asking about riding with Kolby, we didn't get to go, we wound up having to pull his Ody apart to replace his starter.
PostPosted: Thu Dec 14, 2017 11:50 pm
Rand man! Still around. I should have the cylinder back soon. I'm very slow but I have not forgotten you.
PostPosted: Fri Dec 15, 2017 1:50 am
Still here.
I haven't touched your bottom end other than cleaning it. Let me know when you're going to bring it by and I'll start tearing into it.
PostPosted: Fri Dec 15, 2017 2:10 am
I haven't touched your bottom end other than cleaning it. ---- :shock:
Let me know when you're going to bring it by and I'll start tearing into it. ------ :shock:
:-) :-) :-) Baahahahahahahahahaha
PostPosted: Fri Dec 15, 2017 3:44 am
Get your mind out of the gutter Can Odd, there's not enough room for two of us! LOL
PostPosted: Sun Dec 17, 2017 2:54 am
WHAAAAAAT? LOL
PostPosted: Mon Jan 15, 2018 3:00 am
I can't make this stuff up. The shop that has had my parts for 6 weeks not just told me they were stolen, likely right after UPS left the boxes on the front door of the shop. So I'm in need of new parts again. Rand, I may send him to you. I did find a new cylinder and piston stock. was pulled from the oddy right away and then replace with a water cooled system for someone who was racing them. I will find out more soon.
PostPosted: Mon Jan 15, 2018 11:40 am
What parts were stolen? The cylinder and piston?
PostPosted: Tue Jan 16, 2018 12:18 am
Yes, again or at least he thinks so.
PostPosted: Tue Jan 16, 2018 1:01 am
Incredible! What shop..... Just a reminder not to go there!
PostPosted: Tue Jan 16, 2018 2:55 am
Unbelievable.
You would think that with all the thefts of packages after the UPS guy delivers, that businesses would have a strong box outside the door for the UPS guy to put the package. He could then lock it with your lock after the package is put inside. It would be a concrete box, steel lid, hard to get at lock. It would be clearly marked for the UPS guy.
In the big city here they actually showed on the nightly news a goof following the UPS truck and then taking packages after the driver left. It was on video. Yup guy -- know to police. If I ever get selected for jury duty and a homeowner has pummeled a crack head, the verdict will be not guilty no matter what the evidence says.
Yesterday an under cover police van hit a hole in the road and smashed into a business, and then it caught on fire. Someone had stole a manhole cover. Probably sold it for scrap so he could buy drugs.
PostPosted: Tue Jan 30, 2018 11:39 pm
My parts have been recovered. the box was found. crazy.
Registered users: adnoh, Bing [Bot], Garemie, Google [Bot], Lonerider
