It is currently Mon May 20, 2024 1:07 pm
PostPosted: Fri Feb 01, 2019 1:51 pm
Just finished two 350s, both have the front and rear Farr suspension kits, both have the Farr 670 rotax conversions, one is the HO, and then I added power steering to one of them courtesy of Methodical Fabricator. PS was a must for me on this one, tore up my shoulder in a nasty dirt bike crash combined with 12 deg pos caster made it a bear to steer. Next up is a 800cc pilot using another Farr kit, and another 350 Farr build like these only its only a 500cc rotax.
PostPosted: Fri Feb 01, 2019 2:16 pm
Your stuff always looks so clean, like that’s the way it originally came.
Bob
PostPosted: Fri Feb 01, 2019 2:17 pm
You have all the cool stuff Dawn!! Thanks for posting the pics.
PostPosted: Fri Feb 01, 2019 2:32 pm
"The Twins"
Bad ass machines! Great work as always & looking forward to the next 2 builds.
What Engine is that you posted a photo of? :-)
PostPosted: Fri Feb 01, 2019 3:01 pm
Looks like some nice work. Could you post a few more pictures of the power steering. I bought a power steering unit form my pilot and need to install it.
PostPosted: Fri Feb 01, 2019 3:38 pm
Amazing work.
What are your thoughts on the 670 Farr kit? Did you buy the kit with motor (( Internal Combustion Engine ? )) included?
PostPosted: Fri Feb 01, 2019 4:28 pm
CurtisR401 wrote:
"The Twins"
03 summit 800, Farr is building me some custom stuff for it
PostPosted: Fri Feb 01, 2019 4:30 pm
Garemie wrote:
Amazing work.
What are your thoughts on the 670 Farr kit? Did you buy the kit with motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? )) included?
I have bought it both ways, I like the 670s the best for the high speed desert riding I do and the readily available parts
PostPosted: Fri Feb 01, 2019 4:32 pm
Bob
I like installs that look like it was born that way
PostPosted: Fri Feb 01, 2019 4:34 pm
PostPosted: Fri Feb 01, 2019 4:37 pm
Thank you.
PostPosted: Fri Feb 01, 2019 4:38 pm
nice..power steering would be nice to have, I might have to quiz meth up on one
PostPosted: Fri Feb 01, 2019 5:22 pm
https://www.youtube.com/watch?v=H9dH41mMRcc
PostPosted: Fri Feb 01, 2019 5:24 pm
oh. I have seen his vids, I just don't have the tools to make some of the stuff
PostPosted: Fri Feb 01, 2019 6:36 pm
Real nice machines. Thanks for sharing!
PostPosted: Fri Feb 01, 2019 6:41 pm
If you talk to him nicely he might make you a kit, easy to install with only one weld.
PostPosted: Fri Feb 01, 2019 6:49 pm
So what happens to your brake resivors.
PostPosted: Fri Feb 01, 2019 6:51 pm
I see his reservoirs are on the steering wheel :-)
PostPosted: Fri Feb 01, 2019 7:59 pm
Is Farr still producing kits?
PostPosted: Fri Feb 01, 2019 9:11 pm
meegusmaster wrote:
CurtisR401 wrote:
"The Twins"
Holy power plant!!! Love it!
PostPosted: Tue Feb 05, 2019 4:55 pm
how much travel on the rear suspension and what shocks are you using?
nice machines
PostPosted: Wed Feb 06, 2019 11:16 am
They have pilot steering wheels
PostPosted: Wed Feb 06, 2019 11:17 am
nice machines
10 in, the shock bodies are Fox from a XP 900, the springs are from a 800, made the retainers on a lathe.
Yes, but also working on new projects so he may be limiting orders
PostPosted: Sat Aug 10, 2019 9:53 am
One thing that will help with the steering effort is the front rims, my kits are setup for a 10x5 front rim with a 3+2 offset if your rims have a 2+3 offset you are adding an inch to the scrub radius which will make the steering harder. I was under the false impression a while back thinking that a 2+3 rim could be run on either side but the profile of most rims is not same on both sides. When you choose a rim offset like 3+2, it is the first number in this case the 3 that mounts on the hub face, and the valve is on the 2 side.
Registered users: Baidu [Spider], Bing [Bot], Garemie, Google [Bot]
