It is currently Sun Nov 10, 2024 3:43 pm
 Post subject: Salsbury/Powerbloc
PostPosted: Wed Oct 21, 2020 2:11 am
I was planning on making a Salsbury/Powerbloc clutch.
Basically I have an original oddy Salsbury drive clutch and a Powerbloc clutch that came with a machine that I bought years ago. Unfortunately the Powerbloc has the wrong offset for an oddy and the original Salsbury it junk.
The idea is to use the Salsbury bottom end and the Powerbloc top end with the pucks.
Tonight I spent some time making a fake chineseum crank shaft taper end so that I could mount the shivs in the lathe. So far so good. Pics below.
Then I noticed the shaft on the Powerbloc is 1" dia and if I turn down the shaft on the Salsbury to that size then I will only have a .130" wall left. I measured it with some snap gauges. Pics below.
Visions of another dyno style clutch explosion were dancing in my head.
File comment: Fake chineseum crank taper
File comment: Both bottom ends fit
File comment: Measured the wall thickness if I cut down in the lathe
 Post subject: Re: Salsbury/Powerbloc
PostPosted: Wed Oct 21, 2020 12:47 pm
I hear ATV Racing has a large order in with CVTech/Powerbloc for FL400 clutches, but no ETA on shipment/orders. You might give CVTech a call for 350.
PostPosted: Wed Oct 21, 2020 10:26 pm
Failure !!
The more I think about this project the more I think it must be abandoned.
The wall thickness will be too thin on the stem and there may be another clutch explosion. Then we will be deep in the bush and a long way from the truck. Not good.
I just wanted this for a spare anyways and since both were junk there was no loss.
What I might do just for fun is re-face the shivs since they all have grooves and uneven wear. Not likely I will be able to ever use them but it would be fun to do anyways. Plus I have already made a taper shaft to mount the clutches in the lathe.
So in short, this project has ended and will be taken off the winter list.
Thx for the suggestion ZeroClient but I was just trying to make a clutch out of junk parts.
PostPosted: Thu Oct 22, 2020 3:28 pm
Do you think that was a pilot drive unit?
If so I'll take it. I could use the parts
I will even pay you up front.
I need a good cap and pucks and even the movable. My fixed face is pretty good. Sorry I don't any 350 stuff to trade.
PostPosted: Thu Oct 22, 2020 4:48 pm
I have no clue what that unit is actually from.
All I know is that it was on a machine that I bought and it ate up a belt in minutes because the offset is .300 off from where it needs to be.
Also this unit appears to be old school. The cap has no "D", it's a round hole. The pucks each have seven weights and look good to me. It has a black 3" spring. Cap is 5 5/8" dia.
I can take more pics and measurements if you need them.
If you want it and can "actually" use it then it's yours "free" if you pay shipping. Your call. PM me details.
I'll be busy for the next couple of hours so will have to get back to you later tonight in the PM box.
PostPosted: Thu Oct 22, 2020 6:18 pm
No rush. I'll be gone for a few days. Nice of you to offer.
Registered users: Bing [Bot], eseymour72, Google [Bot], hoser, Lanix, MSN [Bot], MSNbot Media, W3C [Validator]
