It is currently Wed May 22, 2024 6:03 am
PostPosted: Sun Mar 21, 2021 11:09 pm
Could I get some help to locate the correct upper ball?
Honda Part number 52395-HE0-003 JOINT, RR. ARM (UPPER), #11 on the diagam.
I can't seem to find a source for one.
Found the below 4 options but the first 2 (same) push in from the front.. mine pushes in from the "rear"..
THANKS IN ADVANCE FOR HELP..
And then one from
1. https://www.truegether.com/listing.html ... 1yEALw_wcB
OR
2. https://www.ebay.com/itm/89-90-FL400R-F ... 2485782720
Found two "look similar" ones on NAPA and Ebay..
Napa?
3. https://www.napaonline.com/en/p/PCQ1601 ... REALw_wcB&
ALL BALLS
4. https://www.ebay.com/itm/383507956175?c ... KfEALw_wcB
PostPosted: Tue Mar 23, 2021 12:20 pm
Did you try Lee Hawkins on fb? He is in a lot of the Pilot pages. I’m pretty sure he has them. They aren’t cheap either.
Bob
PostPosted: Tue Mar 23, 2021 5:16 pm
Thank you for the response Rppjr..
The source on ebay is 96 dollars each.. ouch..
I tried an all balls one of amazon.. just about 1.5mm dia too small.
Guess I will bite the bullet..
Thanks again.
