It is currently Mon May 13, 2024 8:18 am
 Post subject: Fl250 no power
PostPosted: Mon Oct 24, 2022 6:48 am
Hi guys I just picked up a Honda Odyssey fl250 and it fires up ever pull and it idles pretty good and as soon as I give it a little gas it will start to go but will only goes about 10kmph and as soon as I start to give it more gas it just goes blrrrrre like it has no power, when I got it it didn’t have a fuel tank so I just put a smaller one on to test it but I’m gravity feeding it and it look like they are ment to have a fuel pump?
 Post subject: Re: Fl250 no power
PostPosted: Mon Oct 24, 2022 11:18 pm
Some carbs are fine with gravity feed, depending on the float valve.
Have you tried a new plug? If I remember correctly the sticker on the fl250 says to mix the gas at 20/1. That would likely foul a plug with todays higher quality 2 stroke oils. 32/1 is what I ran when I had my 250.
PostPosted: Wed Oct 26, 2022 8:48 pm
So, this could be a few different things. What have you done so far? Did you do a compression check? Clean the carb? Fresh plug with good gap? Does the stator look like it has been rebuilt?
PostPosted: Sat Oct 29, 2022 1:29 am
Is the air filter and spark arrestor clean, restricted flow in or out affects performance then there is clutching issues like broken springs in clutches that allow early upshifting
