It is currently Mon May 13, 2024 11:19 am
PostPosted: Tue Dec 05, 2023 12:24 am
I'm new here, Hello everyone! I've got an FL250. Absolute junk when I bought it from this guy, who got it from a guy. You know the story. Anyways, I've installed a snowmobile Engine, Rotax 377. Replaced all wheel Bearings, Tires around, Brake System, Pretty much everything to make it go. Runs great on a single carb, but it really is designed for 2. Does anyone know if they make a Mikuni-style Dual Carb throttle cable long enough for the Odyssey? Just wondering if anyone else has run into this issue.
Rick
PostPosted: Tue Dec 05, 2023 12:30 am
Welcome new guy:
I do not know if they make this cable for this application.
However I see no reason why you can't fab something up using bicycle cables.
I use bicycle cables to replace the e-brake cable on the FL350's I own and on machine that are brought to my house for re&re.
You can cut the length you want and make the ends you need with melted wheel weights, solder or something similar. Use your imagination.
I do have a negative comment though. That Engine in that machine is gona be dangerous.
Just my opinion.
PostPosted: Tue Dec 05, 2023 12:36 am
Oh I'm well aware. I have enough hours on it to know it is an adult-only machine. Honestly, I probably just need to leave it alone anyways. Thanks for the info, I was leaning toward making a Frankenstein if necessary. Just wanted to get some opinions.
PostPosted: Tue Dec 05, 2023 12:10 pm
Typically you can use the stock Odyssey cable and hook it up to the splitter from the Snomobile throttle cable.
That is how it is usually done on the Rotax Swapped FL350/FL400's
