It is currently Sun May 19, 2024 12:19 pm
PostPosted: Wed Sep 12, 2007 5:00 pm
Their is a metal washer below the seal also
PostPosted: Wed Sep 12, 2007 5:01 pm
You can now see the metal bearing in the center of the seal holder once the washer is removed.
PostPosted: Wed Sep 12, 2007 5:03 pm
The dust seal is removed carefully with a screwdriver then reinstalled with a hoser Pilot rear shock seal driver, I wish I had 10 bux for every tool I have made over the years lol
The seal goes on easy
PostPosted: Wed Sep 12, 2007 5:04 pm
Bottom side everything washed and greased to accept the new seal
First the thin washer
PostPosted: Wed Sep 12, 2007 5:05 pm
Next the seal goes in groove side up, it pushes in by hand
Then the thick washer
PostPosted: Wed Sep 12, 2007 5:06 pm
Finally the retainer ring
http://www.pilotodyssey.com/oilchange.htm
PostPosted: Fri Oct 16, 2009 11:11 pm
And then??? Where or how do you add the oil? How much oil? How much gas???
PostPosted: Tue Feb 16, 2010 5:32 am
the washers were different sizes in the seal assembly there was a thin one in one shock and a thicker one in the other the outer washers were the same size has any one come across of this before ?
PostPosted: Thu Feb 18, 2010 5:36 pm
So your saying it has a extra washer?
