It is currently Fri May 10, 2024 1:59 pm
 Post subject: Speaking of toter trucks
PostPosted: Wed Apr 20, 2011 1:20 pm
A few days ago there was a discussion of toter trucks, here is one I came across that is an interesting idea of how to do a toter/hauler/sleeper.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 324wt_1167" ."..
Or, here is a completely different idea. I don't know anything about these, but this one seems real cheap, maybe Turbo would know more about this type of truck.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 500wt_1182
PostPosted: Wed Apr 20, 2011 1:35 pm
I have seen a bunch of them on the road over the years they are a nice setup and make nice haulers surprised to see that one whit only 116k miles must have been used privately.
One of the options I had for the bus (still could happen) was to shorten up the bus and turn it into something like that hauler just have a back seat for a few passengers then a flat bed setup to bumper pull or 5th wheel haul trailers, only problem with this plan is it requires me to spend 20k on a toy hauler lol Especially with fuel cost and my dumb obsession to drive so far to ride I need to keep my initial cost low as I can or I will be stuck at home.
Interested to see how much this one sells for.
PostPosted: Wed Apr 20, 2011 11:52 pm
The top link is a sharp ride!! I always wanted on like this when I was rodeoing for a living! Sleeper and a truck to haul a trailer... I wonder what kinda MPG it would get pulling my toyhauler???
The second link is an "expediter truck" probably has a lot of miles on it... Used to run as a team truck, meaning always going... I would want to take the box off and put a hitch on the back of it...
PostPosted: Thu Apr 21, 2011 10:39 am
I wouldn't expect the Ford with the 460 to get very good mileage, in the 70's I had two different Lincolns with them, neither of them got very good mileage, but they were the beginning of the EPA engines, maybe they got a bit better as time went on.
The expediter is basically a semi, I thought they were supposed to be good for a million miles, this one has 300,000, is that considered worn out? Also, my understanding is that a fully loaded semi will make between 5 to 7 MPG. If loaded much lighter like this would be, would it get much better mileage?
PostPosted: Thu Apr 21, 2011 3:38 pm
I have talked to guys that made haulers out of semis if you pick the right Engine trans gear combo some are getting as much as 12 mph towing a 8-10k trailer at hwy speeds, buy a semi that has a 450 hp Engine and is setup to haul 100k lbs for life expect to get 6-8 mpg, first thing they do is remove one of the drive axles this removes bunch of weigh you don't need.
PostPosted: Thu Apr 21, 2011 4:19 pm
My thought on the expediter was that it could be used much as it is, strap a generator and some water tanks under the box, cut a couple of windows, put a side access door, maybe spiff up the inside with a kitchen and bath at the very front and go riding. Since it should still have about 20' of open cargo space, a trailer would rarely be needed.
Part of the idea to make it an RV, is that it then doesn't require a special driver's license, or stopping at the various ports of entry or weigh stations. I don't know about other states, but in Colorado, I was able to register the box truck that I converted by having several of the RV features such as water, heat, air conditioning, porta pottie, and a bed in it. I took the paperwork to a regular dealer had them certify that what it had in, got a weight slip and licensed it as a motorhome which made the insurance cheaper also.
PostPosted: Thu Apr 21, 2011 9:28 pm
I have seen them expediter type trucks go for 4-5k I have all the RV stuff I need just need to pull the trigger buy one and transfer it from the bus lol
I found them doing a search for "box truck" first thing I would do is register as a RV when I had the title work done lady at title place don't care, no inspections required just do it, HOWEVER she did say if its not a RV and you get stopped on the interstate better have a LOT of money because excuses wont go anyplace, if I titled it as RV before I took it on the first trip it would meet the requirements :-)
Tires on the bus are the same size as on that truck and like new...
PostPosted: Thu Apr 21, 2011 11:18 pm
you are right the gearing and motor (( Internal Combustion Engine ? )) make a big difference in MPG's... I didnt read the whole add so I never saw the 300,000 miles...
A lot of Pro Rodeo cowboys are using the FL70 from frieghtliner now as a hauler to pull there horse trailers... I don't know what kind of hp or mpg these get though...
