It is currently Tue May 21, 2024 2:35 pm
PostPosted: Thu May 17, 2012 2:04 pm
Prox Rod Kit CR500R 87-01 3.1406 http://t37yt.bju6h.servertrust.com/Pro- ... lick=35177 $73.49 This is still the best price I have found seems to be a good company to buy from.
This Item Fits the Following Applications:
2001 Honda CR500R
2000 Honda CR500R
1999 Honda CR500R
1998 Honda CR500R
1997 Honda CR500R
1996 Honda CR500R
1995 Honda CR500R
1994 Honda CR500R
1993 Honda CR500R
1992 Honda CR500R
1991 Honda CR500R
1990 Honda CR500R
1989 Honda CR500R
1988 Honda CR500R
Notes:
Kit usually comes with a CR500 wrist pin bearing (20X25X29) but its too wide for the 400cc Pilot pistons you need a Pilot wrist pin bearing that measures 20x25x25 Wiseco part number B1023 works probably more available at a better price do a search. PROX part number is 01320
Big end pin measures Prox Big End Pin 26x67.65 mm CR500 '01
Big-end Bearing 22.263520F
PostPosted: Tue Jun 12, 2012 6:54 pm
Shop around guys evilbay is not a deal
PostPosted: Mon Jun 18, 2012 5:59 pm
Other Pilot rod discussions
http://pilotodyssey.com/PO/viewtopic.php?p=12949
http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=5753
http://www.pilotodyssey.com/PO/viewtopic.php?p=17541
http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=7005
PostPosted: Sat Oct 05, 2013 2:51 pm
Prox Rod Kit CR500R 87-01 3.1406 http://www.powersportsuperstore.com/ProX-Connecting-Rod-03-1406-p/4165835.htm $73.49 This is still the best price I have found seems to be a good company to buy from.
http://www.hotrodsproducts.com/ProductInfo.aspx?cat_id=15
PostPosted: Sat Jan 18, 2014 12:31 am
Does anyone know if there is a benefit to using Pro-X rods over Vesrah or Hot Rods? Do any of them to your knowledge have an advantage due to weight, quality of materials, or better bearings?
PostPosted: Sat Jan 18, 2014 4:01 pm
We have discussed this before I forget the exact post but you might find it here
https://www.google.com/search?q=style+g ... S:official
The research I did pointed me to the rods made in Japan seems most the problems came from the rods made in china .
Since I can no longer get the Honda rods I use the Pro-X rods but would never hesitate to use the Vesrah brand rods in anything I own, use and abuse.
If you run across any info please let us know, if you have any questions you cant answer in the search please ask.
