It is currently Tue May 14, 2024 10:25 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jul 18, 2012 11:37 am
I have the first one of Trevor's new style billet heads (s/n-001) and it works well....maybe a little too well!
If you guys are planning on using this head, I would suggest using a thermosiphon setup. If not you may want to put a switch on your water pump to shut it off until the head can get a little heat into the head. If it's below 70 degrees, mine takes forever to warm up to operating temperature! CAUTION: If you interrupt the pump, you will want to put an idiot light somewhere to remind you to turn it on!
PostPosted: Wed Jul 18, 2012 11:45 am
Rand, will the thermosiphon setup be sufficient enough by itself?
PostPosted: Wed Jul 18, 2012 11:54 am
Yes. As the water in the head heats up , it rises. This displaces the cold water in the radiator forcing it downward and into the head. This type of flow system has been around for a long time and I believe has been used on water heating and cooling systems long before being used on an Ody.
Registered users: Bing [Bot], FL670R, Google [Bot], hoser, Q, Rppjr, wyeeoddy
