It is currently Sat May 18, 2024 4:53 am
PostPosted: Sun Mar 18, 2012 9:20 am
Honda part number 91204-HE0-003 Oil Seal Discontinued OIL SEAL (30X45X8)
Honda part number 91203-KS6-004 is the same seal http://www.partzilla.com/parts/detail/h ... 6-004.html
Other applications
2007
(91203-KS6-004) OIL SEAL (30X45X8)
Ride: 2007 CR125 Part Group: CRANKCASE ('05-'07)
(91203-KS6-004) OIL SEAL (30X45X8) (ARAI)
2006
Ride: 2006 CR125 Part Group: CRANKCASE ('05-'07)
2005
Ride: 2005 CR125 Part Group: CRANKCASE ('05-'07)
2004
Ride: 2004 CR125 Part Group: CRANKCASE ('03-'04)
2003
Ride: 2003 CR125 Part Group: CRANKCASE ('03-'04)
2002
Ride: 2002 CR125 Part Group: CRANKCASE ('02)
2001
Ride: 2001 CR125 Part Group: CRANKCASE
2000
Ride: 2000 CR125 Part Group: CRANKCASE
1999
Ride: 1999 CR125 Part Group: CRANKCASE
1998
Ride: 1998 CR125 Part Group: CRANKCASE
1997
Ride: 1997 CR125 Part Group: CRANKCASE
1996
Ride: 1996 CR125 Part Group: CRANKCASE
1995
Ride: 1995 CR125 Part Group: CRANKCASE
1994
Ride: 1994 CR125 Part Group: CRANKCASE
1993
Ride: 1993 CR125 Part Group: CRANKCASE
1992
Ride: 1992 CR125 Part Group: CRANKCASE
1991
Ride: 1991 CR125 Part Group: CRANKCASE
1990
Ride: 1990 CR125 Part Group: CRANKCASE
1989
Ride: 1989 CR125 Part Group: CRANKCASE 87-89
1988
Ride: 1988 CR125 Part Group: CRANKCASE 87-89
1987
Ride: 1987 CR125 Part Group: CRANKCASE 87-89
1986
Ride: 1986 CR125 Part Group: CRANKCASE 84-86
1985
Ride: 1985 CR125 Part Group: CRANKCASE 84-86
1984
Ride: 1984 CR125 Part Group: CRANKCASE 84-86
1983
Ride: 1983 CR125 Part Group: CRANKCASE 83
1982
Ride: 1982 CR125 Part Group: CRANKCASE 81-82
1981
Ride: 1981 CR125 Part Group: CRANKCASE 81-82
PRO-X has these too 30x45x8 part number 41.1-KS6004
PostPosted: Tue Sep 18, 2012 5:53 pm
I beleive this seal is still available from honda.
powersportsplus.com
PostPosted: Sat Oct 20, 2012 8:05 pm
I think I tried them to no avail!!!
PostPosted: Sat Jan 05, 2013 10:25 pm
Try Cheapcycleparts.com I just picked one up.
PostPosted: Sun Jan 06, 2013 12:11 am
Where did you find the right side seal?
Bob
PostPosted: Sun Jan 06, 2013 12:14 am
http://www.ebay.com/itm/Metric-Oil-Shaf ... 255d28b231
PostPosted: Sun Jan 06, 2013 12:15 am
Thanks, That's the one I found just wasn't 100% sure on it.
Bob
PostPosted: Sun Jan 06, 2013 6:57 pm
Bob
Can you order two of these I want one will pay you for it :-)
PostPosted: Sun Jan 06, 2013 7:23 pm
Consider it done Hoser i will get it done within the hour.
PostPosted: Mon Jan 28, 2013 10:14 pm
How did these seals work out Hoser? Was this a viable replacement?
PostPosted: Sat Oct 05, 2013 2:50 pm
Yup is the same as the Pilot seal was different number I have a bunch of them in stock I actually over ordered these some how, they need changed often since the environment behind the clutch is so nasty.
