speedchaser wrote:
a pic of mine
looking in to this braket I'm finding on hole sizes
A = .4160 inch (10.5664 mm)
B = .3950 inch (10.033 mm)
C = .3670 inch (9.3218 mm)
F = .3540 inch (.89916 mm)
with that in mind I think it is not wore that much if at all.
If some one has better to get dim off of let me know or post new findings please.
Now on the bracket it self look to be cast so that is what I'm going to look it to.
Becouse machining out of a solid block will cost a lot more.
Now the other caliper it self the other part with the piston
needs to be looked at as seen above there is ware in some spots
weld up ? or machine and incert stainless steel plates with small taped holes ?
thanks for you time
Speed
Great info, thanks, I will see if I can get better dimensions.
My thoughts on the caliper was to machine it down then add a stainless or 4130 plate,
IMO drilling and screwing would be great, you could also use some JB weld and screws?
The pink arrows in the pic below is where I am talking about.
