It is currently Thu May 09, 2024 10:59 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Mon Dec 08, 2014 7:33 pm
Yes they wear out in the sliding pin areas,plus in the brake rotor slot.
I've had 2 calipers where a hole was worn right thru between the rotor slot and sliding pin.
Depending on your riding ground conditions,sand,rocks,general crap get ground into that slot area/notch and eventually wear thru to the sliding pin hole.
Then the crap enters the pin hole and wears that out too! Aaarggh!
A better way of shielding/protecting that area needs to be addressed.
I fixed up one calliper by rolling my own bush around a suitably sized drill bit shank, from a thin polished sheet of stainless steel.
The SS sheet was just scrap from a kitchen flue,worked perfectly,but everytime I've tried to fix/fill the rotor slot hole,it does'nt last long.
I have lots of pics of it in my threads,maybe the FL800/AC550pilot thread? I'll look.
Thx for the reply. That answers it. Post the pics please when you get a chance.
PostPosted: Tue Dec 09, 2014 7:58 am
well if there is a call for the rebuild able Steel ones
start a new thread if we can get MIN of 10 or more I will run them at the same price $145 free ship in U.S.A.
I build the steel ones to fit the fl350 & fl400
thanks Speed
PostPosted: Tue Dec 09, 2014 8:53 am
thanks Speed
Count me in! :()
Pilot please
PostPosted: Sun Dec 14, 2014 9:16 am
I'm in!
Registered users: Bing [Bot], Duneit, Google [Bot], Rppjr, wyeeoddy
