It is currently Wed May 22, 2024 9:51 pm
Post new topic Reply to topic  [ 532 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22  Next
PostPosted: Mon Jul 15, 2019 1:26 pm
canadian oddy wrote:
TerryH wrote:
I wonder how many Engine failures are from weak pulse pumps that no one ever checked?
Yeah that's kind of my thinking now too.
Based on the number of Engine re $ re on this site, I bet it's a lot of them.
I wonder if this was also a major contributor to the failure rate of the factory original oddy in 1985 ??
Randman and I always got into a gun fight over fuel octane and Avgas. He was able to run his machines with pump gas. I was not that successful with it. The AV fuel gives you a lot of cushion if something is wrong on an Engine. With pump gas it's over instantly.
They had a lot of recalls on the oddy's in 1985 and the factory killed the machine after only one year.
If you are going to put an air cooled Engine behind a seat everything better be spot on spec or it's over.
Imagine trying to jet your carb with an intermittent or low fuel supply ??
It's hard enough for a beginner like me to get my head around anyway much less fighting a intermittent fuel pressure deal that you don't even know exists.
2 new keys in the mailbox when I got home for lunch. Fresh one installed and all buttoned up already. Buddy coming over later this evening to help me stab it back in. I really hope that there is a video of it running before the evening is over.
PostPosted: Mon Jul 15, 2019 1:51 pm
Anyone know amp/wattage pull?
PostPosted: Mon Jul 15, 2019 1:54 pm
Theres only a couple ways that key would have sheared like that. Especially if it only sheared from just the starter motor (( Internal Combustion Engine ? )), I'd bet money a new key will re-sheare again. The keys are only for alignment and cant hold any torque whatsoever, let alone several horsepower from the starter and inertia change from fluctuating RPM. They are only for initial setup and then the torque of tightening the flywheel bolt is the major holder. If I were you I would replace the flywheel nut.
Are you absolutely sure the flywheel contact and crank surfaces are true with no defect? These surfaces need to be smooth and need to mate up perfectly tight and torqued else the flywheel WILL spin again irregardless of the key.
You might try some green loctite though that might not be such a great idea. Food for thought though.
Otherwise you will be right back where you started with a new key sheared.
FYI - Ace hardware usually has different sized flywheel keys cheap if you need.
PostPosted: Mon Jul 15, 2019 1:58 pm
Also I'm interested in that pump. Is there any way it can be relay/wired so that it is only active while the Engine is cranking AND running? This would be for safety. Even by the key/On/Off switch is not exactly safe. Needs to only run while Engine is actually turning over.
PostPosted: Mon Jul 15, 2019 2:53 pm
ZeroClient wrote:
Theres only a couple ways that key would have sheared like that. Especially if it only sheared from just the starter motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? )), I'd bet money a new key will re-sheare again. The keys are only for alignment and cant hold any torque whatsoever, let alone several horsepower from the starter and inertia change from fluctuating RPM. They are only for initial setup and then the torque of tightening the flywheel bolt is the major holder. If I were you I would replace the flywheel nut.
Both the original time and the 2nd time I've had the flywheel off, the nut was tight as was the flywheel itself. It took a good amount of pressure on the puller to free it from the crank both times. I have no clue nor does Methodical. I have been over every minute detail of the whole mess with him. No obvious answer to the issue. Don't know what to do at this point but to try it with a new key and see what happens. Certainly open to anything other than that if anyone has a suggestion.
PostPosted: Mon Jul 15, 2019 2:54 pm
I agree!
PostPosted: Mon Jul 15, 2019 3:03 pm
I would have no idea how to do that. I could not come up with any better way than to energize with the key switch.
The pump motor (( Internal Combustion Engine ? )) literally stops completely therefore pumping no fuel at all if the system is not drawing fuel once it has full pressure. Sorry if this is a stupid question but what condition would cause a safety issue given the way the pump regulates itself?
PostPosted: Mon Jul 15, 2019 3:45 pm
I only know enough about electronics to get myself in to trouble but if I were to work on the fuel pump on only while running issue, I think you could use a diode in your charging wire to the battery so it only gets power while the Engine is charging, you may also be able to wire into the starter button so you get some in the carb while cranking but you may need to isolate that power so the charging system is not supplying power to the starter :shock:
just food for thought, you can get it figured out so if I ever need to put an e pump in I'll know where to look :-)
I have the watercraft carbs on my 670, just bought a carb rebuild kit specifically to get the pulse pump parts. when I took it apart I noticed some damage to the reed sealing surface, I know it was there before, replaced the pump body, so now I get to see how it works.
on a different subject, where did you get the flooring for your trailer, very nice.
PostPosted: Mon Jul 15, 2019 3:56 pm
You lost me at diode. Actually it sound like what you suggested could probably be made to work but honestly, I'm going to go with it as is soooo if you figure it out you can let me know. :-)
The flooring is the small coin PVC from Garage flooring of Co. They had the best deal on it. Free shipping and it's made in the US. They also have the correct glue.
https://www.garageflooringllc.com/g-floor-small-coin-garage-mats/
PostPosted: Mon Jul 15, 2019 10:11 pm
Fired right up. :-) 98 octane and Amsoil Dominator smell really good by the way.
2 heat cycles tonight. Tomorrow night we go for ride #1.
PostPosted: Mon Jul 15, 2019 10:14 pm
Oh my godddd! Woohoooooo
PostPosted: Mon Jul 15, 2019 10:20 pm
That's what I said! :-)
PostPosted: Mon Jul 15, 2019 10:30 pm
TerryH wrote:
Fired right up. :-) (8 octane and Amsoil Dominator smell really good by the way.
Beautiful. That things sounds nice and smooth.
It runs nice and smooth as well. I don't see any Engine vibrations. It just seems to sit there. Very nice.
PostPosted: Mon Jul 15, 2019 10:59 pm
Thanks much CO. It is crazy smooth. Methodical definitely did his magic on it. Apparently the whole key deal was just a fluke. It fired right up tonight. Literally could not get off the start button fast enough on the second heat cycle. Idles perfectly at 1200 rpm.
PostPosted: Tue Jul 16, 2019 6:50 am
That thing runs so smooth! Can’t wait for the ride!
PostPosted: Tue Jul 16, 2019 7:09 am
Thank you!
PostPosted: Tue Jul 16, 2019 9:44 am
Hearing that thing run gave me the warn and fuzzies..lol
I was thinking about the pump running while the buggy was on it's side from a rollover. I could see the possibility of the float being in the down position and the pump pushing fuel out the overflow and possibly into the cylinder.
I think a tip over/bank angle switch could fix the issue?
Terry, I'm surprised to hear you say he lost you at diode. With your electric dragster, I would think you would be well versed? Just to be clear, he lost me at diode too.
PostPosted: Tue Jul 16, 2019 9:55 am
I'll freely admit that my buddy and I did just stand and absorb it while the heat cycles were going on. Feels good for it to run.
I was actually just kidding with the diode comment. :-)
I'll research the tip over switch. That would be ideal.
PostPosted: Tue Jul 16, 2019 10:06 am
A lot of the older motorcycle tip over switches are just a pendulum type switch, probably be super easy to just put one inline on the power wire for the pump. I'm sure there are mercury switches too, but I don't know how they would react on bumpy terrain.
PostPosted: Tue Jul 16, 2019 10:21 am
I see OE ones but they seem to be all on street bikes. Guessing the rough terrain might be a deal killer to using one of those but will research more and see what I can find.
PostPosted: Tue Jul 16, 2019 11:29 am
That's not what I would do.
PostPosted: Tue Jul 16, 2019 12:09 pm
You feel it's ok as is or do you have another idea of something different?
PostPosted: Tue Jul 16, 2019 2:20 pm
Perhaps just a secondary switch for emergency cutoff manually activated would do the trick. Or you could research and induction/coil switch kind of like how a tiny tach works perhaps. I don’t know if there is such a thing though.
PostPosted: Tue Jul 16, 2019 4:17 pm
Bear with me here on my stories please:
1) I have been on fire in my race car. It's not a good feeling. The race cars all have electric fuel pumps. The fitting on the carb broke and the pump kept pumping fuel. The corner crew put me out.
2) I have been in a HUGE crash in my oddy that got me a free helicopter ride to a trauma center in the big city a hundred miles away. I broke my back (crushed L1).
I hit a washout at very nearly top speed of an oddy. My guess is 50+ mph. When I hit the hole the oddy went straight up like a missile, rolled over in the air and I came down on the roof. The impact was so great the sparkplug lead came off and the Engine died all on it's own. I cart wheeled down the road and then rolled down an embankment and got hung up in some trees. The oddy was upside down. I undid my belts and fell out of the oddy.
Now here is the key part: The Engine was off but fuel was leaking out the tank through the fuel cap and dripping on the ground right where I was laying. I was actually watching it come out LOL. I could smell the fuel but I had nothing else to do anyways. Did spend some time killing deer flies and ants that were biting me though.
What I am saying is that in a big crash if you are upside down in an oddy fuel is gona leak out the tank anyways. With and electric pump fuel is only gona leak out if you brake a fuel line.
I am NO electron mechanic. I hate electrical. All I know about it is that if you give it the lick test you're gona end up on your azz. Having said this I still want to comment.
I don't think there is an electrical switch that will work in this situation. On rough terrain the tilt switch will constantly be cutting in/out and the pump motur is probably not going to like that very much, but I could be wrong. All new vehicles have and electrical cut out when you get into a head on crash but it must be reset manually. Not sure if this is an option here.
In my opinion I would put a check valve in the pressure side of the fuel line that goes to the carb and when the machine is upside down it just checks the fuel and dead heads the pump.
But remember #2 above.
Edit: When I get those three electric pumps for my machines I am just gona go with it. If I crash that hard again I hope I am dead.
PostPosted: Tue Jul 16, 2019 7:46 pm
I swapped a 302 into my Jeep 9 years ago and the wire harness that I used had one of those kill switches mounted under the dash
Registered users: Bing [Bot], CurtisR401, eseymour72, Google [Bot], Rppjr
